At approximately 25,000 miles my 2005 RT started squealing at the starter right after it turned over. . I remove the starter and took it apart and cleaned both halves of it with penetrating oil and washed it out really well, then put it back together again. I then reinstalled the starter and the squeal was gone.
Now the bike has 60 thousand miles on it and it started acting up again. . Does anybody else with a hex head have this problem?
Starter retraction squeal
Re: Starter retraction squeal
My guess would be that the starter motor needed cleaning and lubricating...
Did the work today. . Removed the starter. . There was caked on grime on the bendix shaft. . The confusing thing is: the bendix shaft and gear are covered by a hood. That hood only allows exposure of the gear where it meshes with the flywheel. . So the question is where is all the dirt coming from? Could it just be from clutch wear?? It is meshed in the engine case and not exposed to the elements. I gueas dirt could be blown in when the air is reflected at high speed. . So, I cleaned it all up and put a light coat of moly grease on the shaft. . Reassembled. . Starter performed normally.
- Spencert231
To it sounds like you would be an ideal neighbour as I would not have a clue what to do in that situation. I hope it has solved the problem rglassma.
It would be my pleasure to share what I know. I am not the greatest wrench for sure. I think I lack confidence more then anything else. But, I had done it before. So, experience is the best teacher.
I think this will have to be another preventative maintenance procedure along with changing the alternator belt every 35K or so. When it starts to sqeak, I have to take a peek .. :))
- Spencert231
I know how to do something when I am shown normally once is enough unless it's Excell Doc. I suppose confidence is my problem with the scanners. I have to take the wiper arms of my Citroen C4 to remove some large plastic to get behind the dashboard as the drain hole is blocked and I get water ingress in rain i keep avoiding it like the plague, simple enough, but break into a sweat when the spanner comes out lol
Well, I have owned my RT since 2007. I have performed all of the maintenance on it with the exception of the recall items and brake flush. . With over 60K on it, I have found repetition is the best teacher.
- Spencert231
I agree 100% about repetition: EDIP
Explanation
Demonstration
Imitation
Practice, practice, practice, etc
Explanation
Demonstration
Imitation
