Remove Headlight Cluster R1200rt 2007
svcole
Post by svcole »
Hi This is my first post. I need to remove the headlight cluster and change the metal spring plate that holds in the headlight bulb. I cannot figure out how to remove the fairing "Nose". There must be some sequence I ma missing as I need access to the rear of the headlight to pry off the broken one. I have removed lower fairings and screen but can't see where to loosen the whole assembly. Any tip (Videos)?
Re: Remove Headlight Cluster R1200rt 2007
This has been taken out of the Haynes Manual for 04 to 06 Models, should be the same for a 2007 Bike.
Left Click on the photo, then Expand to actual size makes it more legible,
(Top right-hand corner Box with arrow, next to X).
Are these two links any help,
http://bmwsporttouring.com/ubbthreads/u ... ber=914967
http://www.bmrider.com/images/reports/R ... rt%203.pdf
svcole
Post by svcole »
Thanks Dayglo I will give it another try next weekend
svcole
stelyn
Post by stelyn »
Useful  detailed `posting' David  ( just found it )....... ;)
