mounting with a top case
Re: mounting with a top case
RTman10 wrote: And no the stand will not buckle or snap.
In the summer it might dig into the soft tarmac though - same for gravel in car park...
Good advice. After having my Aprilia sink into my mates tarmac drive, I never go anywhere without a puck... the twenty-first century replacement for a squashed coke can.richardbd wrote:
And a great mod to the puck is to drill a small hole in it and attach some string. You can then sit on the bike and pull the puck out, stick in your pocket and off you go
With my top case on (new model not as simple to remove), I have trouble lifting leg over seat to mount. My knees are bad, and it's a stuggle. However, I just bend the knee up as much as I can and grab the pant hem with my right hand and help it over. Works ok. Getting off is easier. I can do the reverse while hopping back a little on my left leg. These bikes are made for short guys with bad joints.turdboman wrote: Any techniques for mounting with a top case , i can't lift leg high enough to just put it over seat !
That's what i finally figured out ,grab my cuff and lift it over seat !!mercator1 wrote: With my top case on (new model not as simple to remove),I have trouble lifting leg over seat to mount. My knees are bad, and it's a stuggle. However, I just bend the knee up as much as I can and grab the pant hem with my right hand and help it over. Works ok. Getting off is easier. I can do the reverse while hopping back a little on my left leg. These bikes are made for short guys with bad joints.
