Top box strip
Pete1200
Top box strip
Post by Pete1200 »
Has anyone stripped a 49l none electric top box down for spraying the grey panel?
Sorry if this is an old topic but I haven't been able to find an answer.
May the road ever be your friend, from leaving home till journey's end.
guest3074
Re: Top box strip
Post by guest3074 »
Yes and it's fairly easy to do, I can't remember exactly and give you step by step guide but after removing the screws from the lid inside you can unclip the outer shell and give it to your local body shop  ;)
Here's a picture of mine off while running the cables for my own brake light  ;)
Pete1200
Re: Top box strip
Post by Pete1200 »
Thanks for that info. I've removed the screws holding the back rest cushion on but quite how to proceed from there I'm not sure. Any ideas would be much appreciated.
Cornishboy16
Re: Top box strip
Post by Cornishboy16 »
how do you get the cable to go thru and out of the bottom of the case
