Tighten your caps!
Nobby
Tighten your caps!
Post by Nobby »
I noticed yesterday that I'd lost the black plastic cap that is screwed onto the end of the lower pannier mounting outrigger.  I then checked the one on the other side and both screws were loose so I removed it completely before the cap fell off and went the way of the one on the other side.
So the moral of the story is, dab a little Loctite on the screw threads and make sure they never vibrate out again!  A replacement is on order.
(apologies in advance for the state of the bike - its seen a fair amount of wet roads lately!)
Re: Tighten your caps!
This came up here a couple of months ago and lots of us found them loose.  Do you ride with the panniers off.  There is a gap in the pannier lug where the bung fits but I don't think big enough to allow it to fall off.
T6pilot
Post by T6pilot »
I checked the screws on my 15 with 4500 miles, all were loose
Buddies new 16 all were loose
Nobby
Post by Nobby »
T6pilot wrote: I checked the screws on my 15 with 4500 miles, all were loose
Yes, I ride with them off.  I don't need the storage on a day to day basis so I leave them off to prevent potential filtering damage.
Steve F
Post by Steve F »
Erm....if you can fit the handlebars through when filtering, then the panniers will fit as well..! ???
richardbd
Post by richardbd »
Steve F wrote: Erm....if you can fit the handlebars through when filtering, then the panniers will fit as well..! ???
Maybe Nobby takes the bar ends off as well...
Tango
Post by Tango »
wrap some tape around the screw heads, won't stop them coming loose, but may prevent loss.
Sensible suggestion.  I'll go and find some black tape.
richardbd
Post by richardbd »
Tango wrote: wrap some tape around the screw heads, won't stop them coming loose, but may prevent loss.
Or even better, leave the panniers on and ride the bike in the way it look the best!
Liverpool Brick
Post by Liverpool Brick »
[size=2px]Or even better, leave the panniers on and ride the bike in the way it look the best![/size][size=2px]
Good point! I've only just got my RT and I'm looking at with panniers on and off and it looks wrong without them. Too fat at the front? My beloved K75S definitely looks good without them but not the RT. Sorry to change the subject.
Andy
1991 K75S, 2011 R1200RT SE
Levisp
Post by Levisp »
Whats wrong with thread lock
richardbd
Post by richardbd »
Liverpool Brick wrote: Good point! I've only just got my RT and I'm looking at with panniers on and off and it looks wrong without them. Too fat at the front? My beloved K75S definitely looks good without them but not the RT. Sorry to change the subject.
Andy
Don't worry about changing the subject Andy.
I'm all in favour of threads about what make the RT look best!
8) 8) 8)
Steve F
Post by Steve F »
Levisp wrote: Whats wrong with thread lock
Yes, exactly. It strikes me that's a better, neater solution to solving this loose screw issue. ???
Too late now.  I've covered mine in sticky black tape.
Attackpug
Post by Attackpug »
Where did I put the bailing wire
