1200RT LC 2015 Cruise Control problem
shoei
Post by shoei »
Just come back from a 2500 mile trip around Europe and the cruise control has been driving me mad....! I've checked the user manual and it should not do this. If the cruise is set and I wish to slow down, you press the switch towards you and this should reduce the speed. Well mine is switching the cruise off and a 80mph with a closed throttle is a pain in the arse. Anyone else had the problem? Dealer will be looking at it soon. Is this the dreaded switch gear problem....again..?
Cheers
Re: 1200RT LC 2015 Cruise Control problem
Had the same problem, ie  switching off instead of slowing down on a 1600 (same switch).  Sorted with new switch.  Should take your dealer 15 minutes to fix.
ACY540
Post by ACY540 »
I take mine in tomorrow for the same issue. It a 2014 LC
Al
