Front disc bolt torque?
- Been liked: 395 times
Re: Front disc bolt torque?
The Haynes Manual for the R1200 dohc Twins 2010 to 2012 gives the following Torque setting.
Front brake disc bolts 19 Nm.
- Has liked: 72 times
- Been liked: 71 times
DaygloDavid wrote: The Haynes Manual for the R1200 dohc Twins 2010 to 2012 gives the following Torque setting.
Thanks David. That explains why I couldn't get passed 25nm without shearing 2 torx bits!
"Tight's tight - too tight is knackered"!
David is correct with the torque settings MacJ quoted the settings for caliper mounting bolts Sullivj wrote:
The front brake caliper mounting bolts are 30 Nm, in both the Haynes Manual & BMW Rider's Manual.
Not if you're looking at the manual for water cooled :silence:DaygloDavid wrote: The front brake caliper mounting bolts are 30 Nm, in both the Haynes Manual & BMW Rider's Manual.
DaygloDavid wrote:The Haynes Manual for the R1200 dohc Twins 2010 to 2012 gives the following Torque setting.
Yes I know, I was referring to the small difference in what I quoted as it's slightly different for the water cooled RT's which coincidently is the same value that MacJ quoted. ::)
What year/model is the bike?Sullivj wrote:Could someone please tell me what the front disc bolt torque should be?
Hey Gents,
I have just checked the front discs and they move ever so slightly. I checked the back disc and it does not move at all. Has anyone noticed the same slight movement?
Thanks. Cheers, Pat
Thanks. Cheers, Pat
Thanks Dave for clarifying the discs tightness issue. After writing my question, I realized the floating/heat dispersion aspects. Notwithstanding my realization, I appreciate you taking the time to answer my query. Cheers Pat
