Shift Indicator
Shift Indicator
I found setting to turn on the shift indicator but have not seen it. What should I be looking for?
Not that I really need it, just curious.
- bieffe
- Bike Model and Year: bmw 1200 rt 2007
Re: Shift Indicator
Depends on which bike do you own, on my RT 1200 07, is probably what is attached below.
Re: Shift Indicator
Look in your handbook it shows you what appears on the dash as you accelerate. Most of us don't bother with it as it comes in at quite low revs.
Re: Shift Indicator
Loads of people asking how to turn it off but this is the first request to turn it on!
:eggs:
:eggs:
Re: Shift Indicator
The shift indicator was introduced on the 2014 water cooled RT's bieffe wrote: Depends on which bike do you own, on my RT 1200 07, is probably what is attached below.
- smileymiley
- Has liked: 6 times
- Been liked: 11 times
Re: Shift Indicator
Ooeer!richardbd wrote: Loads of people asking how to turn it off but this is the first request to turn it on!
:eggs:
Re: Shift Indicator
There are some really smart things on the LC, Pro shift for one. The gear change indicator isn't one of them.
Re: Shift Indicator
bradrcfii wrote: I found setting to turn on the shift indicator but have not seen it. What should I be looking for?
It was on when the bike was delivered, I turned it off after a few hundred miles finding myself wanting to rev each gear higher than it was suggesting to shift at, and now at 12K miles when I'm not pushing it I find myself shifting right about where the indicator suggested shifting--I think it's an rpm to shift at if you're not in a hurry, want the least engine wear and best fuel economy. It taught me to shift much earlier than I might have otherwise but it took nearly 12K miles to figure that out. When racing thru the twisties or otherwise in a hurry I use a broad range of rpm but as I say for just getting around it's fine and low tension.
Re: Shift Indicator
Makes you wonder if BMW think most of their customers are old doddering gits, which could just be true for some of us.
- Has liked: 14 times
- Been liked: 7 times
Re: Shift Indicator
You can ride along in quite a high gear in a leasurely manner and if you look at your instant mpg then change down nearly always you consumption will go down. Something to do with not working too harder labouring. So for me it's a mystery why it's there. probably a throw over from the cars when they borrowed keyless and central locking. I remember someone here who had put something on his bike that I couldn't understand why answered "because I could" . Maybe that's why.
Re: Shift Indicator
Well that's why it's worthless. It works at the other end of the scale probably telling you it might not stall if you change up.
I once remember an owner telling us his misfired in 1st to 4th all the time. Also the rev limiter. Probably not the ideal way to make progress on an RT.
