Migsel mount
TCM
Migsel mount
Post by TCM »
Hi, does anyone know if a migsel mount that fits a 2009 rt will fit a 2010 tc rt?
If it's not broken,you didn't hit it hard enough!
Re: Migsel mount
Migsel offer 3 GPS mounts, http://www.migsel.com/store/index.php?_ ... at&catId=6
Articulated type - up to 2009
Articulated type - from 2010
RAM type - all non LC
Looks like if you've got the up to 2009 articulated type it will not fit the from 2010 TC.
The Ram type - all non LC, fits both.
Re: Migsel mount
If you are talking about the GPS mount that goes above the clocks their site shows 1 up to 2009 and 1 2010 onwards. So they don't think so. The moulding round the instruments are different but the BMW one that seems to use the same connection points fits both.
Re: Migsel mount
This BMW GPS mount fits 2010 - later, https://www.ascycles.com/2/BMW-Motorcyc ... ctID/42143
TCM
Re: Migsel mount
Post by TCM »
Thanks for the quick replies, it's the ram type, my brother has one so i'll try his and let you know what the verdict is!
Re: Migsel mount
Re: Migsel mount
TCM wrote:It's the ram type, my brother has one so i'll try his and let you know what the verdict is!
This thread shows the Migsel RAM type mount & confirms it fits all non LC RT's, https://1200rt.com/viewtopic.php?p=14456#p14456
Artemis posted, "it fits all non-WC RTs.  I had one on a 2007 and it will fit my 2011."
Re: Migsel mount
It can be made to fit earlier models as well as many owners  fitted them when they first came out as they put the GPS higher than the earlier design..
Re: Migsel mount
Would a BMW dealer modify a genuine part to fit another model, when there is a model specific alternative.
Re: Migsel mount
It didn't need to be modified.  Can never remember fitting them just selling them.
From memory you needed to modify or replace the securing bolts.
Re: Migsel mount
The Trim panel upper part has the same part no. 46637682929 for all non LC R1200RT's.
2005 http://www.realoem.com/bmw/enUS/showpar ... Id=46_0906
2010 http://www.realoem.com/bmw/enUS/showpar ... Id=46_1260
