Primary spark plug connectors
Hi does anyone know if I can obtain the connections to crimp on the spark plug wires like in the pics below? I had a damaged spark plug connector but managed to source a new a one. Now I need these to replace the original crimped ones as 1 is damaged
- Been liked: 379 times
Re: Primary spark plug connectors
Have you got a new 3 pin plug like this (complete with wires) & wish to splice it in to the wiring harness.
Hi David yes, I got this from Motorwerks it's fine but I don't like the way the earth has a terminal to secure to a part of the engine or frames, rather than ready to splice.. I don't have any terminals like in your pic. So can't chop it and keep it within the conduit {\rtf1\ansi\ansicpg1252
{\fonttbl\f0\fnil\fcharset0 TimesNewRomanPSMT;}
{\colortbl;\red255\green255\blue255;\red0\green0\blue0;}
\deftab720
\pard\pardeftab720\qc\partightenfactor0
\f0\fs64 \cf0 \expnd0\expndtw0\kerning0
\outl0\strokewidth0 \strokec2 \pard\pardeftab720\qc\partightenfactor0
\cf0 \strokec2 \
\deftab720
\cf0 \strokec2 \
I don't think it pasted well, what I have is the kit from Motorwerks I put the link below.
https://www.motorworks.co.uk/vlive/Shop ... 0&spPage=2
It is not the same as the kit in your picture, I would prefer to splice in the earth too but this one has a ring type terminal for securing to the bike, meaning 2 of the 3 wires will be in the harness conduit then the 'earth' I will need to bolt to the engine or frame, which will work fine but will not look the best. I want to be able to either exchange the actual terminals that are used in the coil connectors thus not requiring the splice, or splice all 3 wires so they are all in the conduit. Any ideas?
OK, cut off the original damaged 3 pin plug, remove the terminals from the Motorworks supplied repair kit, solder the 3 wires from the two items together using heat shrink for insulation, hopefully, the conduit will slide over the re-made connections, if necessary stagger the lengths so the joint area doesn't become too bulky.
How to use heat shrink: https://www.youtube.com/watch?v=LD9kBax1DDk
Cheers David I think that's the way I will go ..
I have just ordered this from eBay which looks like the same connectors as used in the spark plug connector for the sum of £4.24! Hope fully I can trim the original harness and fir these into the new connector. I will keep you posted when they arrive
