Posts: 2670 Joined: Wed Jan 27, 2016 6:25 am
Been liked: 45 times
Post
by Casbar » Sun Nov 13, 2016 9:00 pm
Skeezix wrote:
How big is your gas tank?
Gasoline is 6.183 pounds per gallon.
US or UK (imperial) gallon? There is a difference.
Post
by guest2360 » Sun Nov 13, 2016 9:04 pm
But nowhere near 50kg difference just on fuel.
richardbd
Posts: 1468 Joined: Sat Dec 13, 2014 8:40 pm
Been liked: 2 times
Post
by richardbd » Sun Nov 13, 2016 9:22 pm
Ah - but that raise two problems...
1. How much does a pound weigh in new money?
2. Whose gallon - yours or ours?
Post
by guest2360 » Sun Nov 13, 2016 9:28 pm
What's to formula US to proper. Can't be much more than a gallon difference in a tank.
Posts: 8306 Joined: Fri Nov 07, 2014 7:29 pm
Been liked: 389 times
Post
by David. » Sun Nov 13, 2016 9:58 pm
One US gallon is approximately 0.832674 Imperial (UK) gallons,
or
one Imperial (UK) gallon is approximately 1.2 US gallons.
David. on Sun Nov 13, 2016 10:06 pm, edited 1 time in total.
tony23
Posts: 35 Joined: Mon Sep 05, 2016 10:35 am
Post
by tony23 » Sun Nov 13, 2016 10:02 pm
Petrol weighs about .74 kg per litre so 25 lit tank approx 19 kg. Specific gravity is less than water
Post
by guest2360 » Mon Nov 14, 2016 7:21 am
That explains why bikes exported to the US do 20% less to the gallon.
DaveCly
Posts: 263 Joined: Mon May 18, 2015 12:57 pm
Has liked: 44 times
Been liked: 24 times
Post
by DaveCly » Mon Nov 14, 2016 7:37 am
Ohhh my head hurts :alas:
Post
by guest2360 » Mon Nov 14, 2016 7:42 am
Good job a lb is still a lb over there or we would be here all day.
leonjennings
Posts: 96 Joined: Sat Oct 29, 2016 10:26 am
Been liked: 1 time
Post
by leonjennings » Mon Nov 14, 2016 11:47 am
so 6 penguins fill 3 tanks in 6 minutes, how may minutes does it take 3 penguins to fill they same amount?
2012 SE
guest3954
Post
by guest3954 » Mon Nov 14, 2016 1:15 pm
RTman10 wrote:
Hold up guys, the best RT's ever built are the 2010-13 models.
Building sandbag fire wall as i type....... :kacsint2:
You are obviously in denial mode and you know full well they were stop gap models with a borrowed engine. All down to the extended development time of the LC .
And the borrowed tuned down engine fitted to the TC is the best engine they ever built.
Post
by guest2360 » Mon Nov 14, 2016 1:21 pm
One of the reasons they threw it away and started again. When they run out of bits they will probably stop using it in the Nine T.
Sprintgull
Posts: 493 Joined: Tue Jul 05, 2016 12:41 pm
Post
by Sprintgull » Mon Nov 14, 2016 1:29 pm
Be careful. Put US gallons into a UK tank and they don't fit properly. Next post will be to ask about a mysterious rattling noise.
Post
by Casbar » Mon Nov 14, 2016 1:32 pm
That would be my fillings when riding our 2010 RTP with the best engine they ever built 8) Got to say though, don't feel as much vibration though the bars as my LC
