EXhaust leak at Clamp
mcbrid
Post by mcbrid »
Hi all,
I have noticed what appears to be a leak at he joint between the exhaust pipe and the back box on my 2013 R1200RT
How common is this as a fault and how easy to fix please?
Thanks
Mike
Re: EXhaust leak at Clamp
I assume you mean where the end can connects to the exhaust pipe.  There is one large clamp on the joint.  As it's normal to remove the end can to remove the rear wheel it's probably just not been clamped up,enough.
mcbrid
Post by mcbrid »
I have two clamps - one either side of a plastic box which I assume is the 'flap'
It seems to be leaking on both sides of the joint so goodness knows what's been going on there.
Strip down job tomorrow by the sounds of it which sounds quite straightforward then if there are no gaskets on other trickery to watch out for>
Thanks
The exhaust flap valve has clamp alignment marks on it.
The clamps are marked for GS or RT, they need to be aligned with the mark for RT fitment.
Clean all the mating surfaces & re-assemble using high-temperature grease e.g. Copper Slip.
Ensure that the flap valve is pushed up the exhaust pipe to the shoulder & likewise with the silencer.
The clamps also need to be as far forward to the shoulder as they will go.
The torque setting for the clamp bolt is 28 Nm.
mcbrid
Post by mcbrid »
Excellent David - that will be a big help
Thanks
If the clamp is thought to be the problem, heavy duty exhaust clamps are available from Stig Fasteners in Darlington.
The clamp band is 20mm wide & appears to be continuous, unlike the BMW ones.
mcbrid
Post by mcbrid »
Looks like a worthwhile modification - thanks
I'm in Darlo an'all
Called to see Mark at Stig Fasteners today, got some stainless nuts & washers for my XJ650.
juniorswailing
Post by juniorswailing »
Is there a gasket of any sort to fit between the two ends of the respective pipes?
Meet The New Boss, Same As The Old Boss
juniorswailing wrote:Is there a gasket of any sort to fit between the two ends of the respective pipes?
No.
juniorswailing wrote: Is there a gasket of any sort to fit between the two ends of the respective pipes?
No. Just make sure its all clean before sliding them together.
Has liked: 81 times
Been liked: 147 times
a light smear of silicone sealer on assembly is good for sealing exhaust joints without gaskets.
juniorswailing
Many thanks guys. Getting it fixed tomorrow.
