Please see the attached photos of a RAM type ball/bolt for mounting my Garmin. This method uses one of the RT handlebar bolt holes, and uses a bolt with a RAM ball on the end for mounting a satnav type device. Could anyone provide a link to where I can buy one.
Also, the handlebars are secured by 4 bolts, but instead of using allen headed bolt, they use a kind of star headed bolt. Please see attached image 2164. What is the correct term for this type of bolt and what size are used on the RT bars?. I have a similar type drive, but largest I have is stamped as T30. This isn`t big enough to fit this size of bolt head.
Mounting kits for a Garmin 340LM
Re: Mounting kits for a Garmin 340LM
Ah - Torx. I got that bit :thumbs: What size are they though?
- Been liked: 389 times
T45 (M8 x 30mm)BBT600 wrote:Torx. What size are they though?
This looks very similar, http://www.ebay.co.uk/itm/BMW-R1200RT-S ... 1789549570BBT600 wrote:Could anyone provide a link to where I can buy one.
Thanks again David. I don`t suppose you know the thread length of these bolts? Or if anyone else knows please advise thanks.
RealOEM says, M8 x 30mm, if there is any doubt, remove one & measure it before ordering the ram mount.BBT600 wrote:I don't suppose you know the thread length of these bolts?
