Screen cleaner
Cas21
Screen cleaner
Post by Cas21 »
i always clean my screen by giving it a good soak to soften the little bugs and then wash it as normal.
Keep looking at Rainex to give me better vision when the heavens have opened
Any views or indeed better tips?
Cheers
Levisp
Re: Screen cleaner
Post by Levisp »
I always look over my screen so for me its my visor that needs to shed water for clearer vision. However to protect my screen, make getting bugs off easier and bead water I use a wax. A pure wax has no abrasives so will not harm your screen. I use Poorboy's Natty's Blue Liquid Wax. Also heard good reports of Bilt Hamber Double Speed Wax.
chrisvh
Re: Screen cleaner
Post by chrisvh »
Only use the the Rainex specialy formulated for plastic. The normal car Rainex causes problems I believe.
T6pilot
Re: Screen cleaner
Post by T6pilot »
Several companies make rain repellent for plastic
Only one I am comfortable using is RAIN B GONE by Cee Bailey's
Works as advertised, needs reapplying after several hours of heavy rain though
leonjennings
Re: Screen cleaner
Post by leonjennings »
old fashioned pink windowlene
2012 SE
smileymiley
Has liked: 6 times
Been liked: 11 times
Re: Screen cleaner
Post by smileymiley »
leonjennings wrote: old fashioned pink windowlene
Now that's a blast from the past  ;)
Levisp
Re: Screen cleaner
Post by Levisp »
I'm sure it cleans but will it protect ? The point about using a pure wax is that it protects. Basically modern waxes once cured act as a barrier. They also add shine ( note they do not polish ) and bead water very effectively. I get many comments about how clean my bike is and I'm often asked how I do it. Basically I use a car wash and plenty of low pressure water from a hose. However because most of the bike is protected in wax the dirt does not get ingrained into the paintwork and washes off easily.
The screen gets a battering from bugs. Clean carelessly and it will soon get scratched. When I get back from a ride I cover the screen with wet J-Cloths and leave from a few minutes to soften the crud and then clean. I try to be as gently as possible. The screen gets waxed probably every month.
blastfurnace
Re: Screen cleaner
Post by blastfurnace »
I'm a big fan of plexus.  Been using it for years on my windshields and visors.
mhr43
Re: Screen cleaner
Post by mhr43 »
Very much agree. I use a wet towel to soften bugs etc, the carefully wipe off.    I am a fan of a good quality wax on the screen and  helmet visor. It improves visibility in wet weather.
Paggers
Re: Screen cleaner
Post by Paggers »
I don't use any sort of protection because doing at least 250 motorway miles each week - plus whatever I decide to do as social riding on the weekend - anything I put on would wear off pretty quickly. For removing the bugs - and for most other cleaning around the bike short of a full wash - I just use 'all purpose cleaner'. I was put onto this by a car detailer I worked with a few years ago. He swore by it for hand cleaning and I have to say it seems to work well for me. I just spray it on, give it a few seconds to loosen stuff up, then wipe it down using a microfiber cloth. Sometimes I have to use a second application for stubborn bugs.
I should also add that despite doing an average of 1k miles per month, a lot of it on the motorway, I have never had a screen go cloudy on me. I think the plastics used in modern screens are fairly robust - as long as you don't use abrasives on them.
timminator
Re: Screen cleaner
Post by timminator »
blastfurnace wrote: I'm a big fan of plexus.  Been using it for years on my windshields and visors.
Same here.  I don't know if you can get Plexus in the UK, but if you can, give it a try.  It was designed originally for the aviation industry, and is very high quality stuff.  Acts as an anti-fog agent, cleans, fills small scratches, and seals.
[attachimg=1]
BMW MOA #210438
paulgelineau
Re: Screen cleaner
Post by paulgelineau »
Been a pilot and aircraft owner since 1987.  After a flight I always use warm soapy water, soft cloth, rinse and dry.  Then Plexus for the polish.  It's made by BTI and I've always gotten mine from Aircraft Spruce.
Thought I'd try it on my 2015 R1200RT and partner's 2014 F800GT.  Great results.  No haze or fogging after a season of riding here in the Okanogan Highlands of WA USA.
This isn't a promote.  Just thought I'd pass along what works for us.
Cheers,
Paul G.
pkpilot
Re: Screen cleaner
Post by pkpilot »
paulgelineau wrote: Been a pilot and aircraft owner since 1987.  After a flight I always use warm soapy water, soft cloth, rinse and dry.  Then Plexus for the polish.  It's made by BTI and I've always gotten mine from Aircraft Spruce.
Cheers,
Paul G.
I have found that Pledge works on both my aircraft and motorcycle windscreen quite well.  Much less expensive too.
Our Gee
Been liked: 29 times
Re: Screen cleaner
Post by Our Gee »
Pledge for me too, applied after a good thorough wash with normal car shampoo.
Has liked: 424 times
Been liked: 348 times
Re: Screen cleaner
An old thread I appreciate but still relevant.
Plexus, much loved but a bit pricey @ £30+ from Amazon
Clearview which does the same job @ £13.99, if only they did it in a small pump spray bottle for visors -
https://www.ebay.co.uk/itm/154803615863?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=HtRlzljaQDW&sssrc=2349624&ssuid=PpUzP1hWSH2&var=&widget_ver=artemis&media=COPY
