My USA 17RT does a odd thing, with the bike running and the high beams on, then turn the bike off - the low beam light stays on. 10 seconds later the halo lights turn on, then 10-15 seconds later both turn off. If the low beams are on when turning bike off then lights act normal.
I'm wondering if I could impose on one of you to do this with your 17RT and see what happens. Thanks in advance.
17RT lights
- smileymiley
- Has liked: 6 times
- Been liked: 11 times
Re: 17RT lights
Just tried mine and it does exactly the same thing..... the lights do take a very long time to switch off!
I'll ask my BMW mechanics next time I'm in.
Re: 17RT lights
smileymiley wrote: Just tried mine and it does exactly the same thing..... the lights do take a very long time to switch off!
It's just the Linbus system shutting down. What's on when you turn off effects how it does it.
- smileymiley
Re: 17RT lights
Re: 17RT lights
smileymiley wrote: Thanks John
Well I trotted off to my Garage and did a test, It was dark in there, so started bike, switched to main beam, then switched off the bike, all the lights went off immediately. Mine is a 2014 though so perhaps different.
Re: 17RT lights
That's because it thinks it's a car.
You should think yourself lucky. My trike has come with some pile of sh... called a Garmin 590. Horrible screen . Being swapped tomorrow but I suspect it won't help. Just goes to,prove the Navigator might be a Garmin but not just a clone
- michaelc2710
- Has liked: 51 times
- Been liked: 66 times
Re: 17RT lights
[size=2px]It maybe like most modern cars. I think they call it welcome home lights.[/size][size=2px][size=2px][size=2px][size=2px]When you pull up in modern cars you turn off and then flash the main beam and the lights stay on for a preset time, so you can see where you are walking.[/size][size=2px]
