Rubber care
- timminator
- Been liked: 2 times
Rubber care
What do you use to clean and preserve the rubber pieces on your RT? I'm referring mostly to the dust boots on the swing-arm, but there are other flexible pieces as well. The manual discourages the use of silicon-based products: "Rubber parts - Treat rubber parts with water or BMW rubber protection coating agent. ATTENTION - Use of silicone sprays for care of rubber seals. Damage to rubber seals. Do not use silicone sprays or care products that contain silicone."
BMW MOA #210438
Re: Rubber care
Silicone dissolves rubber, mate. That's why you use water-based lube with rubber
Just low-pressure wash would do the trick.
What is your major malfunction, numbnuts!?
Re: Rubber care
I use ACF on all the rubber and black plastic, bring it up a treat
R1200RT LE San Marino Blue
- Been liked: 379 times
Re: Rubber care
Me too, plus any nuts, bolts or other fasteners can get a coating of ACF-50 from the oily rag whilst applying to the black areas.aweight wrote:I use ACF on all the rubber and black plastic, brings it up a treat.
Re: Rubber care
I use Gummi Pflege on my RT and on my cars' rubber seals.
https://www.amazon.com/nextzett-91480615-Gummi-Pflege-Rubber/dp/B004B8GTQG
Re: Rubber care
WD-40 Multi-Use works well and does not contain silicone.
