oil brand
oil brand
I've read the subject on oil, my question is what brand, Valvoline?, Castrol?, Penzoil?, Shell rotella t6 on the label I read "heavy duty diesel engine oil" , I understand 5-40 w synthetic is to be used , but does brand name matter? its for my 2012 r1200rt with 28,000 miles if that matters. Also if the valves are seated in by now, do I still have to recheck valve clearance every so often ? Thanks
- Been liked: 395 times
Re: oil brand
Since 2012, BMW Motorrad has re-aligned its published recommendations globally to only two engine oil viscosities for all engine types:
ADVANTEC ULTIMATE, SAE 5W-40 (API SN/JASO MA2) recommended for the following 2005 & later models: K1200 RS/S/GT, K1300 S/GT, G450X, HP2 Sport, K1600 GT/GTL, S1000 RR/R/HP4, and all LIQUID-COOLED R1200 Models.
ADVANTEC PRO, SAE 15W-50 (API SJ/JASO MA2) recommended for all other models.
IMO, the oil brand is irrelevant providing it meets or exceeds the manufacturer's recommended specifications.
Re: oil brand
The valve clearance check service interval is every 6,000 miles. From experience with both a 2010 & 2012 TC RT, the valve clearances rarely need adjusting. However, for what it takes to check them, I certainly wouldn't let them go unchecked.tomsrt wrote:Also if the valves are seated in by now, do I still have to recheck valve clearance every so often?
- timminator
- Been liked: 2 times
Re: oil brand
No, liquid cooled is 2014 or later.BBT600 wrote: Does “liquid cooled” apply to oil cooled engines?
BMW MOA #210438
- timminator
Re: oil brand
And also, as David says, brand is not as important as making sure specifications are met. If you are member of MOA, they had a 25% coupon for Castrol Power1 a while back, but I'm guessing it has expired by now. This is the oil I choose to use, rather than paying $16/qt for Advantec. Although you will get many opinions that say Advantec is the only thing you should use.
https://www.amazon.com/gp/product/B008MISDII/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
BMW MOA #210438
Re: oil brand
I have an 05 rt with 82k on it. I will continue to use the old spec asI have for 14 years. It runs fine.
Sent from my SM-G930V using Tapatalk
