Looking for HID lighting clarifications - what is needed?
I have a 2013 RT
Looking for some HID low beam lighting clarification. I know there are a lot of threads about this, but they all seem to be missing some basic info. Lots of people have commented about installing the lights, but I haven't found much about the components they used. Most manufacturers offer a CANBus ballast option. Is this needed? They also offer "no fault" relays, but I don't know if this is needed or not.
I am just trying to find out what is needed and if it is plug and play or if some additional tapping and spicing is needed.
I am specifically looking at the DDM Tuning 35w 4300K lights.
http://www.ddmtuning.com/Products/DDM-H ... 35W-or-55W
Thanks!
Re: Looking for HID lighting clarifications - what is needed?
Had a set about 5 years ago on a other bike. One still works, other burned out after 3 years. Changed bulb and ballast, they are not that expensive.
On the RT a bought a UltraCanBus. Yes, more expensive, but had no issues with. I don't know about your model/year bike, but mine was not easy
to install on the bike, so I removed the light assembly and installation was a breeze. Need to drill a hole in each cover behind the bulbs. I used a
hole saw, but don't remember what size. DDM provides some good rubber seals, so don't have to worry about water getting in there. Other than that,
everything is plug and play. I have 35w 4500K. Once you are done, when riding at night you will notice a huge difference! Good luck!
temesvar wrote: Had a set about 5 years ago on a other bike. One still works, other burned out after 3 years. Changed bulb and ballast, they are not that expensive.
Thanks for the info, temesvar!
- blokeonthemove
Have a look at the latest MOT rules, as I understand it they have to have wash and self levelling, certainly for cars, otherwise a fail.
blokeonthemove wrote: Have a look at the latest MOT rules, as I understand it they have to have wash and self levelling, certainly for cars, otherwise a fail.
Not sure our MOT rules apply in North America
- Been liked: 21 times
The draft MOT (UK) rules for 2018 state that any headlamp that has been converted from halogen to HID should be rejected.
The OP of this thread lives in USA. The UK MOT applies for, as by definition, to UK.
