Annoying things about the R1200/1250RT LC - what are yours?
guest4915
Re: Annoying things about the R1200/1250RT LC - what are yours?
Post by guest4915 »
Dip beam/ high beam switch is awkward and unlike most other motorcycles.
PeteM
Post by PeteM »
Pickaxe wrote: Dip beam/ high beam switch is awkward and unlike most other motorcycles.
Interesting, I like it - particularly the way it combines with the flash
I don't find it awkward. In fact I find it a lot better than having to fumble for a rocker switch like we have on our FJR1300s
Malcvtr
Post by Malcvtr »
sup909 wrote:
Gotta link for that? I would be curious to se that.
Yep. Me too.
PeteM
Post by PeteM »
bandytales
Post by bandytales »
YES, totally agree. I used to like a bike I had that had the dip switch below the position of where the indicator switch is (on the Wethead). It was push to dip push, push for high, so it always toggled to the setting you needed. On that bike, the horn was a trigger in roughly the same position as the dip switch is on the Wethead!
However, to the point. I have added a 15 - 20mm extension piece to the current Wethead dipswitch and it now falls to hand much more readily.
