Battery Tender
ScottC
Battery Tender
Post by ScottC »
Hi I did a search for which type of battery tender to get for 2006rt. Didn’t find out which one people have most success with.
Thanks in advance
PeteM
Re: Battery Tender
Post by PeteM »
ScottC wrote: Hi I did a search for which type of battery tender to get for 2006rt. Didn’t find out which one people have most success with.
Thanks in advance
Optimate
Has liked: 61 times
Been liked: 134 times
Re: Battery Tender
PeteM wrote:
Optimate
Same here, you can get a lead to plug straight into the accessory socket which has always worked for me.
smileymiley
Has liked: 6 times
Been liked: 11 times
Re: Battery Tender
Post by smileymiley »
PeteM wrote:
Optimate
+1
Has liked: 81 times
Been liked: 148 times
Re: Battery Tender
+1 for the optimate, although I've also got two Oxford oximisers at twenty odd quid each which work perfectly well.
Been liked: 402 times
Re: Battery Tender
If anyone is after an Oxford Oximiser, they are currently doing a 900 (888) Anniversary edition for less than 30 GBP.
emlevy
Re: Battery Tender
Post by emlevy »
I’m using 0.75mA Battery Tender Jr.’s on all my bikes, connected directly to the battery, and they work fine. About $22 each in the U.S.
Re: Battery Tender
A battery which is maintained fully charged with a trickle charger is most unlikely to sulfate. If this is the case, why pay around twice as much for a fancy battery charger with de-sulfation modes which shouldn't be necessary. With the latter, the recovery modes (high voltage) are not active unless the battery is removed from the bike to protect the electronics.
