My bike has keyless ride and central locking.
The filler cap locks with the ignition on, unlocks when the ignition is switched off (to permit re-fuelling) then after 1 - 2 minutes locks again. It's a very clever system when it works.
My bike was in for a service at 35,000 miles and the tech said that it showed a fault, indicating that the filler cap was not locking. It's hardly the end of the world, because it closes and seals, but I suppose it should lock. I hadn't realised there was a fault because I'm not in the habit of checking that it has locked when I know it has clicked shut.
I now have to decide whether I want to replace the entire filler cap assembly to cure this fault or do I just live with it.
One day I will pluck up the courage to ask how much a new filler cap assembly will cost ..... :-X
Fuel filler cap not locking
Re: Fuel filler cap not locking
Have you tried a spray of WD40 , i did on mine when it was sticking as i noticed that water can sit inside it.
I had the oppposite issue on mine: filler cap didn't unlock when I cut the power off. Of course my tank was quite empty and I didn't have enough carb to go back home.
Happily enough it ended up unlocking after 10 to 15 tries (switching power on and off). Once returned home, I cleaned it with air spray and put a little bit of WD40.
Had it replace Under waranty by BMW.
Dirt had get Inside it and blocked it.
I've got plenty WD40.
Time to give it a try ☺
- Bike Model and Year: R1250RT
Had my 2017 MOT’d today and the garage struggled to open the keyless filler cap. It had been stood over winter and not used. After the test I fiddled with it and managed to open it while holding it down. A good dose of WD40 solved the problem.lolo28fr wrote: I had the oppposite issue on mine: filler cap didn't unlock when I cut the power off. Of course my tank was quite empty and I didn't have enough carb to go back home.
My filler cap opens and closes OK, it just doesn't lock - see my other thread :
Keyless, Central Locking, Fuel Filler Cap
The bike is keyless and the central locking still works on everything - except the fuel filler cap.
