24000 Mile Service
- Been liked: 395 times
Re: 24000 Mile Service
Engine oil @ £18.98 per litre, oil filter @ £18.52 & FD oil @ £32.46 per litre.
David. wrote: Engine oil @ £18.98 per litre, oil filter @ £18.52 & FD oil @ £32.46 per litre.
I make that £126.90
David. wrote: The FD unit doesn't take a litre of oil.
That comes to Engine oil +filter +fd oil = £102.
What happened to other checks and labour.
Seems rather expensive for oils & filter.
Hiflo HF160, £6.59, https://chainsandsprockets.co.uk/produc ... gKwMfD_BwE
Castrol Power 1 Racing 4T 5w-40, £10.98 per litre, https://www.demon-tweeks.com/castrol-po ... lsrc=aw.ds
Castrol Syntrax Long Life Differential Oil 75W90, £19.49 per litre, https://www.demon-tweeks.com/castrol-sy ... 4d4980346e
That comes to Engine oil + filter + fd oil = £70, a saving of £32 or more depending on how much FD oil is required.
Brake fluid is changed, initially after one year, then every two years. The bike is 2018, therefore, not due until 2021.
David. wrote: Oil & filter, FD oil plus collection & delivery was £108.
But thats just materials. What was the total service cost.
“they will be charging around £100 per hour for labour”
So only charging around £70 per hour then
The labour charge is based on an hourly rate where the AW = 12.00 for one hour. On the invoice below, the rate is £93.60 + 20% VAT = £112.32.
Now I am confused. You said total service cost was£180 Yet the cost above was over £250
- Has liked: 81 times
- Been liked: 147 times
Beagle wrote: Now I am confused. You said total service cost was£180 Yet the cost above was over £250
I don't think its David's invoice, he'll have just got an image from Google for reference.
£180 was quoted by a.n.other for a 2 year (second annual) service on a 2018 Wethead.
The invoice for £254.08 if for someone else's 2012 Camhead, for what looks like an annual/6,000 miles service. Used to demonstrate how the hourly labour rate is broken down into AW portions for selected service items, (AW 12 = 1 hour).
