Final Drive Rubber Boot P/N 33357708117
Kunkies
Post by Kunkies »
Just completed my 24K mile interval service and when replacing the final drive rubber boot noticed the clips that snap to the final drive have started to separate from the inner diameter of the rubber boot  >:( .  Time to replace.
Q.  Do I need to drop the final drive down to replace the rubber boot, or just snap in place?
Thanks in advance for your advice, feedback...
-Bob
Been liked: 389 times
Re: Final Drive Rubber Boot P/N 33357708117
This is the FD unit rubber boot.
The FD unit will need to be dropped and separated from the (splined) shaft drive to replace.
Boxflyer
Been liked: 19 times
Post by Boxflyer »
Deleted
Kunkies
Post by Kunkies »
OK, I'm now chalking my question up to shear stupidity.  Of course, I need to drop the final drive to install a new rubber boot, how else would it go around the drive shaft!!!?  :-[  Sheepishly, -Bob
Thank you for the confirm David.
Boxflyer; great write-up.  If it wasn't for you and your 6 part video series, I would have never mustered up the courage to conduct interval maint. on my RT wet-head.  Thank you so much for what you do!
-Bob
