Headlight bulb replacement on 2015 RT
Rwslater
Post by Rwslater »
Holy crapola!! Has anyone tried to install cyclops LED headlights in the RT? I have a 2015 and to get the headlight quadrant out you have to completely take the front end apart/off.  It's nearly impossible  :thinking:
srpuywa
Re: Headlight bulb replacement on 2015 RT
Post by srpuywa »
I let the dealer do it when I had a 2015
Nick Evans
Been liked: 6 times
Post by Nick Evans »
I fitted them to a 2009RT; I left the light cluster in but removed the plastic around the dash (left the clocks in) dash bezel, made it very easy, (probably completely different on a 2015 bike, but it might be worth looking at.)
PatM
Post by PatM »
It's not impossible, just take your time. BTW I did mine without removing the headlight assembly. It's just easier to insert the bulb when the assembly is out.
Ride safe!
Rwslater
Post by Rwslater »
srpuywa wrote: I let the dealer do it when I had a 2015
I first took it to the Stealership, they charged me an hour to look at it and then said they couldn't do it.  >:(
Rwslater
Post by Rwslater »
Nick Evans wrote: I fitted them to a 2009RT; I left the light cluster in but removed the plastic around the dash (left the clocks in) dash bezel, made it very easy, (probably completely different on a 2015 bike, but it might be worth looking at.)
Thanks to BoxFlyer, the LED headlight bulbs were replaced without taking the bike apart.  The low beam was easy, just reached up from the front. For the high beams we removed the speakers and got in through there.  Thanks BowFlyer for all your help!
Boxflyer
Been liked: 19 times
Post by Boxflyer »
Deleted
Motorhead1977
Post by Motorhead1977 »
Are the bulbs the same in a 2015 as for a 2018? If so which Cyclops LED bulbs did you use? I'd like to upgrade my 2018. TIA
Boxflyer
Post by Boxflyer »
Here is the Cyclops kit I installed last week…except that it was for the 2015 so this is the part number you will need when they are back in stock.
CIL-RT-18.
https://tinyurl.com/y9bwwnk9
For my own 2016RT, I only installed the center (low beam) and was VERY happy with just that.
I have Clearwater Darla's, so the total illumination down the road is spectacular…I actually like to fill in the darkness of remote roads with some of the more "warm" light of the standard OEM H1 high beams, so just decided not to upgrade all the lights, just the low beam.
bandytales
Post by bandytales »
Boxflyer wrote:
I am curious about what changes on model years 2015 to 2016, then 2019 to 2020 that would require a different lighting kit? Anyone know?
jordanv
Post by jordanv »
I used these bulbs from Amazon for a total cost of $110 and they work great - much much brighter. I was able to install without taking the light assembly out.
https://www.amazon.com/gp/product/B07XK ... UTF8&psc=1
[size=2px]https://www.amazon.com/gp/product/B084Q ... UTF8&psc=1[/size]
Boxflyer
Post by Boxflyer »
Deleted
Boxflyer
Post by Boxflyer »
Andy, I just got off the phone with the primary Tech at Cyclops…and he stated that physically the replacements for the H7 low beam and the H1's that are for the 2 high beams are the same for all years, but that the break out of year groups has been in response to the way BMW updates the software within the bike.
All the lights they have for our BMW's are CAN-BUS compatible, but it's how they design them with differences to ensure that they will work with whatever BMW has changed along the way from the introduction of the WetHead.
jordanv
Post by jordanv »
The LED's that I bought have a beam pattern that is an exact match of the halogen bulb. Most of the new LED's match the Halogen filament position and shape to ensure proper beam pattern.
Boxflyer
Post by Boxflyer »
Deleted
