Question on the 1250engine for 2020 owners
[size=2px]The 1250 engine has been noted for so some peculiar noise...If you own a 2020, have come across any eccentric noise in the engine: like a tik or a pop coming out the exhaust (these are the ones I have seen on the forums [/size]
- michaelc2710
- Has liked: 50 times
- Been liked: 64 times
Re: Question on the 1250engine for 2020 owners
you normally only hear a 'pop' when changing up or down using the pro shift, as it cuts the ignition on the gear change for a split second. Most cars with a DSG (Direct shift) gearbox do the same pops. It's nothing to worry about and doesn't cause any damage to the bike.
Some people (me included) like the pops
- Talisker
- Bike Model and Year: R1250RT LE 2020
- Been liked: 5 times
I have not heard any eccentric / unexplained, pops or bangs from my 1250. It has, thus far, behaved in a very civilised manner regardless of manual or quickshifter gear changes.
- Has liked: 14 times
- Been liked: 7 times
Same for me :-) PeterTalisker wrote: I have not heard any eccentric / unexplained, pops or bangs from my 1250. It has, thus far, behaved in a very civilised manner regardless of manual or quickshifter gear changes.
- Old Foxy
- Has liked: 10 times
- Been liked: 22 times
I get the occasional "pop" when changing gear (downshift with quickshifter) but nothing else. Hardly noticeable (I think I only heard it, as I had changed from a K1600 GTL, which was much, much quieter).
Old Foxy
Old Foxy
michaelc2710 wrote: you normally only hear a 'pop' when changing up or down using the pro shift, as it cuts the ignition on the gear change for a split second. Most cars with a DSG (Direct shift) gearbox do the same pops. It's nothing to worry about and doesn't cause any damage to the bike.
It only bothers me hearing him!
Motorbiking is a life, not a hobby. Ride with Pride.
