Mirror retention cables
Has liked: 424 times
Been liked: 348 times
Horning make a cable to harness the mirror to the bike if it comes away from its mount by collision or shock, such as a pothole.
According to the description it covers ‘05-‘13, are they necessary for the LC models as well?
exportman
Has liked: 9 times
Re: Mirror retention cables
Post by exportman »
Hi
My 2017 already has them
jackronner
Been liked: 9 times
Post by jackronner »
OR, just use a zip-tie.  Just make sure it's loose enough to still pop the mirror out a bit to cut the tie if you need to remove the mirror for any reason.
This thread on BMWMOA, https://forums.bmwmoa.org/showthread.ph ... r-fell-off also suggests that on a Wethead,
"the mirrors are supposed to be tethered to the bike so they can't fall to the ground".
It seems the mirrors may be but the covers aren’t, I knocked the n/s one off when I caught it with my elbow in the garage yesterday.
7vwh
Has liked: 16 times
Been liked: 40 times
Post by 7vwh »
My cable is attached to the cover (2014 RT).
Perfect 👍
Nick Evans
Been liked: 6 times
Post by Nick Evans »
Get a bit of wire and 2 blue ring crimps, crimp them up and you have your tether. Strong enough to hold mirrors anyway.
:)  Yep, I'd thought about some 25-30lb breaking strain plastic coated wire used on fishing traces plus a couple of the wire crimps used to secure the loops. It's flexible, light, and strong enough to do the job.
jackronner
Been liked: 9 times
Gotta say again:  a couple of zip ties and you're done.  Quick, simple and cheap.  The assembly is not very heavy.  With any of the DIY tethers proposed here, you can't make it too long or loose or when it pops off it will hang and bang your faring at motorway speeds;  too short and it'll be difficult to snip the zip if you need to remove the mirror assembly.
