RT mirror upgrade
Buckingham
RT mirror upgrade
Post by Buckingham »
I had these mirrors on my 2010 RT twin-cam - genuine BMW mirrors including adaptors to bolt straight on - these make a big improvement on the standard mirrors, one of the best and most simple mods to an RT.
Fits the twin-cam 2010-2013,  not sure if they will fit the earlier RT.  Not suitable for the RT-LC.
£55 posted to regular UK address.
jackronner
Been liked: 9 times
Re: RT mirror upgrade
Post by jackronner »
Can you post a pic of where the attach to the bike?  They appear to have old-school clamps.  Do they interfere with the windscreen when it's lowered?
jackronner wrote:Can you post a pic. of where they attach to the bike?
Found this photo from Max BMW, I believe that the mirror clamps replace those fitted to the top of the brake & clutch lever mounts.
https://shop.maxbmw.com/fiche/PartsDeta ... AL-MIRRORS
Buckingham
Exactly correct - thanks
jackronner
Been liked: 9 times
Buckingham,  You're right that these don't fit earlier (or later) RT's.  A shame, since the stock mirrors are awful.  I wound up fitting old-fashioned mirrors with parts from a hardware store (ironmongers, for you Brits).  I'll not offend you folks by showing a pic.  They ain't pretty, but they work.  I call such mods "Iron Mongrels".
Buckingham
Sold via the RT facebook group.
Thanks for all the interest.
Jack_the_Lad
Been liked: 4 times
Post by Jack_the_Lad »
Just use a pair of what BMW call pipe clamps, pn [size=11px]32 72 8 532 971, item 9 here [/size]https://shop.maxbmw.com/fiche/DiagramsMain.aspx?vid=58550&rnd=09082020
These allow you to use any screw-in mirror that has the right thread.  I have a pair of GS mirrors which work very well.
Whoever designed those useless idiotic stock mirrors on the RT should be forced to use them, permanently.
JtL
R1250RS • R1200RT • Commando 850 Mk 2a
Buckingham
Worth noting, BMW changed the right hand mounting for the twin-cam 2013 year model only (final year before the LC).
The 2013 has 6mm mounting screws for the brake master cylinder,  whereas the 10-12 model years had 5mm screws.  In short, if you've got a 2013 you need a different mounting clamp.
