2011 R1200RT rough or normal idle?
I posted this on a different forum and got somewhat mixed answers.
Hi everyone first post here. Have a 2011 RT with 48k miles that I just bought. Original owner was an old man so I’m guessing these are gentle miles. I can’t tell if I’ve got a rough idle or not, what do you all think? Also, my last bike has some spark issues and I’ve become hyper aware of any surging and can’t decide whether my RT surges or not. Here’s a video of the idle, let me know what you all think? On Cruise control at speed, my speed stays the same but it's a bit jerky, is this normal?[/font][/size]
https://www.youtube.com/watch?v=HYbpf8YFy8Y
Re: 2011 R1200RT rough or normal idle?
Do you have access to a GS911 tool? That will take a lot of the guess work out
That said, a good dose a Techron injection cleaner then I would consider new plugs, valve check and a throttle body balance.
Hey Jim, thanks for the reply! The bike had a pre-sale inspection about 2k miles ago by bmw that said the bike looked clean. I’m guessing they checked this?
Also, plugs changed and valves adjusted 9k miles ago. Valves checked 6k ago and throttle bodies were also synced 6k ago.
Knowing most dealers, they do a safety inspection onlyarazai wrote: Hey Jim, thanks for the reply! The bike had a pre-sale inspection about 2k miles ago by bmw that said the bike looked clean. I’m guessing they checked this?
Do you have any service records @48,000 miles it’s due for a valve check, plugs and balance
Yes I have extensive maintenance records with basically no lapse. Valves adjusted 9k ago and checked 6k. Plugs changed 9k ago. TBS 6k ago.
- Been liked: 387 times
I think the idle is normal and not rough.arazai wrote:Here’s a video of the idle, let me know what you all think?
The Haynes manual suggests that if the cruise control is thought to be faulty, first check the throttle cable adjustment.arazai wrote:On Cruise control at speed, my speed stays the same but it's a bit jerky, is this normal?
- Has liked: 1 time
- Been liked: 9 times
Arazi, Are you new to boxer Beemers? There's always a good bit of vibration with the boxer, which may seem strange if you're used to more than two cylinders. It didn't seem unduly rough or uneven to my ear. The throttle blips seemed responsive, with little hesitation. Do you know how old the fuel was and whether water might've gotten in it if not garaged? I'd predict that, after a week, you won't notice anything unusual, and that this may just be a case of buyer's paranoia. But you might try swapping similar model bikes with someone for a comparison and for the swapper's comments on your bike. Enjoy it, they're great machines.
- Been liked: 29 times
Sounds normal to me as well. Incidentally I a Hexhead RT which idled much , much worse than this, so bad in fact that I had to turn the engine off after about half a minute as I couldn't stand the mechanical distress the engine was suffering. BMW changed just about everything including Plugs, Coils, Lambada Sensors and the ECU. All to no avail. Part exchanged it to a BMW Dealer for a Twincam which idled lovely.
