Mirror assembly popping out?
- Has liked: 1 time
- Been liked: 9 times
On my 2009RT, this was a problem (though tethered). I guess the rubber pop-in receivers were tired/worn. I took a thin 1/77 mm plastic-coated wire, cemented it into the grommet and pressed the mirrors home, and they haven't popped out since. I've seen in another post that the cam heads on now have a securing screw system. About time. Now, if only they'd change the awful placement of the mirrors.
- Has liked: 1 time
Re: Mirror assembly popping out?
TJRL, Once again, the guys you design these bikes don't tour. E.g., the fairings that send the cold air directly up your sleeves! I jury-rigged a set of convention mirrors on the existing holes so I don't have to look down and away from the road, and so I can see past a touring load that blocks the view from the stock mirrors. Ugly but effective.
