R1250RT 2021 spare aux plugs
Re: R1250RT 2021 spare aux plugs
If you buy the ready made splitter then when you come and sell the bike you can put it all back to original and sell the splitter. So effectively the splitter would only cost say £30. What's not to like. Easy stress free solution. Job done. Another good find by David.
I think I will take the Aux plug out and check a few suplliers first, If I can't buy the connectors then I might bite the bullet.
- Been liked: 379 times
Could replace the OEM aux. socket with one of these and use spade connectors, (check panel hole size).
This is part of a kit from Motorworks for £20, Motorworks BMW Motorcycle Specialists - Shop - Spares and Accessories the socket on its own is probably available for less.
As fitted to a Camhead, BMW R1200RT / R1250RT forum - The BMW R1200RT/R1250RT forum
Found this quote from Nippy Normans, "Tyco connectors (more recently renamed as TE connectors) are the standard fitment on BMW motorcycles since 2004".Greengrass wrote:I will take the Aux plug out and check a few suppliers.
May help in the search for connectors.
Thats good to know, I sent some photo's to a BMW dealer to see if he could ID them, Haven't heard back yet.
I'll check oy the TE info cheers
These look good both male and female available from the UKhttps://www.mouser.co.uk/ProductDetail/TE-Conne ... gLCgfD_BwE
Ordered the connectors from NN so hopefully sorted, man thanks.
I'll post up the finished product when its completed.
The NN quote was used to identify the manufacturer of the BMW OEM connectors. I thought they might just be a pair of generic connectors rather than suitable to fit between the OEM aux. socket and connector. Sorry for any confusion but for minimal cost, I hope they work for you.Greengrass wrote:Ordered the connectors from NN so hopefully sorted.
I will use one pair regardless so it's only £4, I think I can risk that
Should the NN connectors be unsuccessful, found this thread on the R1200R Forum, USB Plug project in need of help | BMW R1200R Forum discussing the same.
Although I don't use ebay, I'm continually drawn towards this seller in Bulgaria, Accessory BMW Rt Gs R F St GT K power outlet splitter Hella Din connector | eBay looks like it's exactly what is required for less than £25.
Thanks for that, I've seen the Bulgarian e-bay seller he/she may be a future option.
Taken from the R1200R forum:- https://www.r1200rforum.com/threads/2013-r12r-connector-for-accessory-socket-wiring.56227/
Housing: P/N 1-1703498-1
Contact: 1718760-1 This is a crimp pin,
Seal: 967067-1
Seal: 967067-1
Does look like a nice neat ready made cost effective solution.Greengrass wrote:The Bulgarian ebay seller may be a future option.
SolderSeal connectors included, SolderSeal Wire Connector Kit - Online Wire Solution
This photo has lead me to further investigations, looks like I might have found the mating (male) connector as posted on the K1600 Forum,Greengrass wrote:
Hex ezCAN driving light conversion | BMW K1600 Forum
This photo shows the new aftermarket male plug on the LHS.
Mouser p/n (Manufac p/n) Description
571-1-167096-1 (1-1670916-1) 2P Mcon-1.2 Receptacle
571-1452671-3 (1452671-3) Mcon 1.2 - LL (locking lance)
571-967067-1 (967067-1) WIRE SEAL 24-18AWG
