2021 R1250RT LE self cancelling indicators
Greengrass
Post by Greengrass »
Can the dealer set the indictoar self cancelling system to off or a long distance say 500m as a default.
I just can't get used to the bloody things swithing off too early.Even my examiner has commented on it.
I'd prefer to have manual control of the bloody things.
Re: 2021 R1250RT LE self cancelling indicators
Greengrass wrote: Can the dealer set the indictoar self cancelling system to off or a long distance say 500m as a default.
They won't stay on for the 3 chevron on a motorway off slip, but that is 300 yards. My solution, either indicate later or re affirm just before the 100 yards. The thing is with self cancelling, you really don't want them to stay on longer or you may forget to cancel, you shouldn't rely on them or it can give false indication if staying on too long. Never had an issue with IAM or RoSPA tests because I invariable cancel manually, so its only an issue on Motorway off slips and I do as described above. But to answer your specific question, don't know, because I have always worked around it. Find someone with a GS911 and see if it is an option.
Viking John
Post by Viking John »
I seem to remember there are only 2 options, one long and one short.
I think Casbar's comment confirms that the longest is less than 300 yards.
I do not believe there is an option to choose anything else.
Greengrass
Result, dealer advised that the OEM default profile can be adjusted on the 2021 RT.
It has a number of options which I'll confirm on Friday when the centre stand gets replaced.I'll try and take a screen shot of the options if anybodies interested.
Happy days
Has liked: 45 times
Been liked: 42 times
I just push the button again before or when they go off. It is better than the old way where they stayed on until I remembered to turn them off 😡
mondeoman
Post by mondeoman »
Greengrass wrote: Result, dealer advised that the OEM default profile can be adjusted on the 2021 RT.
Happy days
I would like to see that please Greengrass.
Mondeoman
Greengrass
Had them switched off today and here's the screen shot of the options, fairly limited to be honest.
Once the computer is plugged in and set-up it's a simple screen selection took few minutes.
So they won't self cancel anymore. So instead of having to remember to give them another prod to keep them on, you will now have to remember to switch them off all the time. Loads of potential to confuse other motorists there. But good there are options  8)
Greengrass
It's not been a problem for the last 40 yrs, so they'll be just like my other bikes.
Greengrass wrote: It's not been a problem for the last 40 yrs, so they'll be just like my other bikes.
Good for you, as long as your happy, that is all that matters.
Has liked: 540 times
Been liked: 487 times
Greengrass wrote: Had them switched off today and here's the screen shot of the options, fairly limited to be honest.
Who did it? a BMW dealer?
Greengrass
Yes dealer software required.
