I am looking for the 10 pin round connector (red indicator inside) that connects to the top case wiring harness for a 2017 R1200RT [/font][/size]The wiring harness part number is 61128354792. This harness fits multiple 1200 and 1600 bikes, but it sells for @$300. All I need is the connector. Does anyone know of a source or part number for this barrel connector?[/size]
The pictures show what the connector would plug in to
I am looking for a plug
- Stu
- Has liked: 555 times
- Been liked: 512 times
Re: I am looking for a plug
Simply put! you cannot buy this part separately! it comes with the top box
You can't even buy the wiring loom!
I have searched high and low in the past as I was positive I had seen them for sale but you just cannot find it at all
Unless the dealers can order it
- michaelc2710
- Has liked: 50 times
- Been liked: 63 times
Your can buy normal 5 pin connectors and cut the other round plug off, keep it safe and solder back on if selling the bike
- Has liked: 1136 times
- Been liked: 304 times
Try going to a vehicle breaker. All BMW cars use the same plug and socket as our bikes. With a pair of wire cutters, you should be able to remove the plug/socket with enough wires attached.
