Checking Antifreeze level?
Has liked: 53 times
Been liked: 46 times
With all of this summer heat, I am more concerned with the level of my antifreeze. I have found that it is nearly impossible to see the level through that tiny port in the fairing. (I use Prestone rather than the BMW blue). I have been considering adding something highly visible to float on top of the solution; something along the line of mini ping pong balls. I am just trying to figure out something that isn't going to decompose or otherwise cause problems. Any suggestions?
OTOH:Is there some sort of dye that I can use?
Re: Checking Antifreeze level?
Looks like Prestone is yellow and designed to mix with other makes of antifreeze with out affecting the original colour.
Prestone Coolant/Antifreeze - YouTube
With the RT coolant expansion tank being slightly opaque, perhaps there is a good reason for BMW blue.
Why Is Coolant Different Colours? | Prestone (holtsauto.com)
Has liked: 133 times
Been liked: 69 times
Hi,On wethead shine a torch from the front of bike by radiator at level of bottle an the level becomes very clear to see.
Has liked: 424 times
Been liked: 348 times
BoB21 wrote: Hi,On wethead shine a torch from the front of bike by radiator at level of bottle an the level becomes very clear to see.
I can never see the level through the peephole on my 2018, and invariably have to take the panel off to peer inside the opaque bottle to see the level.
Why can’t they make it a darker distinctive colour or find a better way to display it?
Why can't they make the coolant expansion tank out of something which is transparent not opaque.
joeducati
Bike Model and Year: 2019 R1250RT
Has liked: 11 times
Post by joeducati »
[/quote]
Agree, pretty tough to see the level, even with the blue stuff. I just got my bike so I pulled the panel off to make sure of the level and it was below the minimum. After I put the panel back on I pointed my bright flashlight from the front and looked through the peep hole and could barley see the level then....
Only use penlike torch and shows up well through peephole when shined from correct position. If remember correctly from front amd shine up. Always f about bit till find right angle.
Has liked: 1152 times
Been liked: 306 times
Some antifreeze is Bioluminescent. Much easier to see with a LED black light even through the smallest hole.
