Probably this one Martin -
YTX20H-BS High Performance AGM, on special at £90 from Halfords
https://www.halfords.com/motoring/motor ... 39878.html
Battery replacement OEM or Lithium Ion??
- Has liked: 484 times
- Been liked: 81 times
Re: Battery replacement OEM or Lithium Ion??
Well yuasa uk recommended to me for my 19 1250RT the YTXH14 BS so I ordered one. I removed the oe battery which was an Exide for BMW and found it to be of a larger capacity and taller in size.
I’ve contacted where I purchased it from in the hope they can exchange it for the yuasa YTX20CH BS.
- Been liked: 395 times
The mdsbattery.co.uk website suggests that the Yuasa YTX16-BS replaces the original BMW AGM battery, part # 61218531121.
The YTX20CH-BS is the same size but higher performance.
The Yuasa UK website recommends both the above batteries.
I was talking about yuasa the manufacturer direct. Emails from them suggest the ytx14 which is wrong and why I ended up with the wrong battery, mds have now sorted this out so tomorrow will hopefully be delivery day.
Out of interest, where are the Yuasa motorcycle battery manufacturers located.
[/quote]
Looks to be Swindon
YTX16-BS, https://www.yuasa.co.uk/ytx16-bs.html
YTX20CH-BS, https://www.yuasa.co.uk/ytx20ch-bs.html
Both batteries are Length 150mm x Width 87mm x Height 161mm, (see Tech Spec).
This looks like the Exide for BMW battery, https://www.james-sherlock.co.uk/shop/r ... ery-detail 151 x 87 x 161mm.
- Steve398
- Has liked: 424 times
- Been liked: 348 times
- 0EC0C060-9226-4DD8-A3E0-440542FA1E68.png (479.53 KiB) Viewed 973 times
