Do the Tubular Handlebars Change the RT Riding Position?
Re: Do the Tubular Handlebars Change the RT Riding Position?
Back to the cheap Chinese bar risers.
ret46
Bike Model and Year: R1250RT
Canada
Post by ret46 »
Thank you to everyone that commented and added information. I still am not sure whether to include them in my order though.
RET
Has liked: 1152 times
Been liked: 306 times
David. wrote: Mon Nov 21, 2022 7:02 pm Back to the cheap Chinese bar risers.
Well made but done use the Chinese bolts that come with the raisers
Doctor T wrote: Fri Nov 25, 2022 2:15 pmWell made but don't use the Chinese bolts that come with the risers.
Spot the difference, Chinese (top) vs Ilium Works (bottom).
ret46 wrote: Fri Nov 25, 2022 1:34 am I still am not sure whether to include them in my order though.
ret46 wrote: Wed Nov 16, 2022 1:29 am I would love 'higher and wider' as I am coming from an adventure bike and really like the upright seating they provide.
How about the standard cast bars and a pair of these, https://www.shopbmwmotorcycle.com/produ ... bar-risers
"44.5mm Taller and 50mm Wider (compared to original position), these are the true measurements taken at the wrist position."
Has liked: 133 times
Been liked: 69 times
Just been playing on configurator and when you select tubular handlebars the image shows grips in same position as standard bars from all angles.
Appreciate only for illustration but pretty acurate on other aspects.Enjoy your morning David :-D looking at what could be.
Left click on images to enlarge.
I agree with Darren (BoB21), looking at the bars in relation to the mirrors and the reservoirs either side of the TFT screen, they appear to be in the same positions.
Think the bar end weight might be a fraction shorter but only difference from overhead and 360 views that i could see. Tempted David? :thumb:
Think you could be right Darren, look at the bar end in relationship with the ball end of the clutch & brake levers. Perhaps the tubular bars need less end weight which would seem practical.
But when comparing the end of the grips, they look the same in relation to where the clutch & brake levers are notched to break in a fall. Making the grips the same width apart.
Has liked: 81 times
Been liked: 147 times
BoB21 wrote: Mon Nov 28, 2022 5:21 pm Tempted David? :thumb:
He's too tight :lol:
With the tubular bars you have a wider scope of fitting aftermarket bars and raisers
Another reason folks may fit the tubular bars is, it'll be easier to add "Farkles".
ret46
Canada
Post by ret46 »
Has anyone found risers that work on a R1250RT with tubular handlebars? All the searches l have completed only show risers for the 'standard' handlebars. I guess risers that fit the GS would work, but maybe not. I wonder how much the bars can be lifted without having to modify brake lines and/or electrical wiring?
RET
ret46 wrote: Tue Dec 06, 2022 12:41 am Has anyone found risers that work on a R1250RT with tubular handlebars.
Found this thread on BMWLT, https://www.bmwlt.com/threads/2021-r125 ... rk.192524/
This bike is fitted with bar risers from VMT, https://voigt-mt.de/BMW-R-1250-RT-21_1
ret46 wrote: Tue Dec 06, 2022 12:41 am I wonder how much the bars can be lifted without having to modify brake lines and/or electrical wiring.
From the photo, they look like this version, https://voigt-mt.de/Handlebar-risers-wi ... -handlebar which have an offset 30mm up and 24mm closer.
"No modification to the vehicle necessary"
ret46
Canada
Post by ret46 »
Wow thank you David as I did not find the risers in my searches!! I just updated my order with the dealer for my 2023 build and added the tubular handlebars. To be honest I actually prefer the look of the tubular 'bars and if down road I need/want risers it is much easier and better looking then standard handlebar risers.
Thanks to everyone again,
RET
