Hi everyone!
I'm new to this forum and in need of Help! Earlier today, I decided to do the brakes maintenance on the RT. I had the speed bleeders, GS911 WiFi, etc. Everything looked easy... until I screwed up and let the brake fluid get below minimum in the front reservoir. Now I have no front brakes .
Any idea how to solve this? I mean, the fluid won't bleed now and when I pull the front brakes... nothing.
Dan
2015 R1200RT BRAKES BLLEDING
- Bike Model and Year: R1200RT 2015
- Has liked: 4 times
- Been liked: 2 times
- Stu
- Has liked: 540 times
- Been liked: 487 times
Re: 2015 R1200RT BRAKES BLLEDING
Hi Dan and welcome to the forum
You will have an air lock within the brakes stopping the flow of fluid
There is plenty of ways to resolve this
The cheapest and quickest but the dirtiest way is to pump the brake lever then hold it back and crack the banjo bolt on the master cylinder
but a word of warning!! you must have a lot of rags wrapped around the banjo bolt and you will get brake fluid coming out so everything in the area must be covered
Alternatively and my preferred method is to use a large syringe with a bit of pipe on and push fluid up from the caliper to the master cylinder then bleed as normal
Or you can use the syringe and pull fluid down the line with vacuum
Thank you so much! I will try the syringe method and see if I can get it to work. I can't believe how fast I got a response...
- Been liked: 284 times
I use this,couldn't be any easier(although the syringe is easy)
https://www.venhill.co.uk/vampire-vacuu ... wk011.html
Other makes are available
- Stu
I have a cheap one of amazon that cost me £19burridge01 wrote: ↑Wed Jan 04, 2023 9:29 pm I use this,couldn't be any easier(although the syringe is easy)
It works fine for pulling fluid through
Thanks everyone... I used a syringe that I found in the kitchen Easily I pulled from the caliper using a short piece of tubing; completed the bleeding and everything works as it should.
I'm one of them blokes that when it comes to presents 3 times a year I have difficulty thinking what I want/need.I inevitably end up with tools that I don't really need but I do like a bit of tool porn so I give the buyers/givers suggestions and they never let me down,especially the women.Few years ago she was with me in MachineMart and I stood looking at a work bench,woke up on me birthday and inside me card was a receipt for said bench
She's grateful I let her out the kitchen when I want presents
- Has liked: 1075 times
- Been liked: 281 times
That's the same i use. Had it for years. I was a lot cheaper back then.burridge01 wrote: ↑Wed Jan 04, 2023 9:29 pm I use this, couldn't be any easier(although the syringe is easy)
itdoesntmatter glad you sorted the problem out. This is the whole point of this forum. Like minded people helping each other out. Members on here are always willing to help with their vast amount of knowledge.
- Stu
I am exactly the sameburridge01 wrote: ↑Thu Jan 05, 2023 2:25 pm I'm one of them blokes that when it comes to presents 3 times a year I have difficulty thinking what I want/need.I inevitably end up with tools that I don't really need but I do like a bit of tool porn so I give the buyers/givers suggestions and they never let me down,especially the women.Few years ago she was with me in MachineMart and I stood looking at a work bench,woke up on me birthday and inside me card was a receipt for said bench
I'm a sucker for tools and all the family get a list off me of what I want too
I had my ramp bought for me too
- Bike Model and Year: R1200RT 2016
- Has liked: 2 times
Next years Christmas Turkey with have an interesting after taste.....
