Dealing with corrosion!
Has liked: 559 times
Been liked: 519 times
While the bike was on the ramp I noticed that the left throttle body was pretty badly corroded in a couple of places
And to be Honest looking at it I think someone has had a go at it before
I took the plunge and removed it and removed all the lose flaking paint gave it a sand to rough it up masked it up and gave it 4 coats of black hammarite smooth
And to be honest I am pretty impressed with the result! the paint is a very good match to the original
While I was at it I also stripped the spot light brackets as they was showing signs of rust showing through
I was also pleased with the outcome of those too
Has liked: 81 times
Been liked: 147 times
Re: Dealing with corrosion!
Looks good :thumb:
simbo wrote: Sun Jan 08, 2023 7:10 pm Looks good :thumb:
Cheers
Not that its going to matter as you can't see them with the fairing on but I know its done :lol:
Has liked: 484 times
Been liked: 81 times
sakm wrote: Sun Jan 08, 2023 5:58 pm While the bike was on the ramp I noticed that the left throttle body was pretty badly corroded in a couple of places
Nice job looks professional!, my 2019 has the scab on the right TB , I was going to try and remove my centre stand for powder coating but I might spray it now.
Panman40 wrote: Tue Jan 10, 2023 8:08 am Nice job looks professional!, my 2019 has the scab on the right TB , I was going to try and remove my centre stand for powder coating but I might spray it now.
My centre stand is on the list to get a tidy up too
sakm wrote: Tue Jan 10, 2023 9:09 am My centre stand is on the list to get a tidy up too
Those springs look pretty tough to disengage… tempting to use brush hammerite :lol:
Panman40 wrote: Tue Jan 10, 2023 4:45 pm Those springs look pretty tough to disengage… tempting to use brush hammerite :lol:
Yes I agree! But at least they have something you can use the pull the springs
Others I have removed have just the spring ;)
Has liked: 81 times
sakm wrote: Tue Jan 10, 2023 6:14 pm Yes I agree! But at least they have something you can use the pull the springs
Put the bike on the centre stand and place washers between the gaps in the spring, push the bike off the stand and the spring stays extended and easier to remove. Repaint the stand then reverse the procedure. :thumb:
This is how Normski did it on a GS.
David. wrote: Tue Jan 10, 2023 7:05 pm This is how Normski did it on a GS.
Its different on the RT There is actually something to use as leverage too
But that way looks a cracking idea :thumb:
sakm wrote: Tue Jan 10, 2023 7:12 pmIts different on the RT.
Is it like this.
If so, this should do the trick.
Yes thats the one @David. :thumb:
Bike Model and Year: NUFFINK
Been liked: 327 times
Never had trouble removing a spring using one of these
Although I've never used the washers for spacers,that is 1 I shall remember and use in the future :thumb:
Here's another idea using a ratchet strap, fast forward to 9:00.
burridge01 wrote: Tue Jan 10, 2023 7:37 pm Never had trouble removing a spring using one of these
Thats what I was planning on using :)
