Dealing with corrosion!
- Stu
- Has liked: 559 times
- Been liked: 519 times
While the bike was on the ramp I noticed that the left throttle body was pretty badly corroded in a couple of places
And to be Honest looking at it I think someone has had a go at it before
I took the plunge and removed it and removed all the lose flaking paint gave it a sand to rough it up masked it up and gave it 4 coats of black hammarite smooth
And to be honest I am pretty impressed with the result! the paint is a very good match to the original
While I was at it I also stripped the spot light brackets as they was showing signs of rust showing through
I was also pleased with the outcome of those too
- Stu
Re: Dealing with corrosion!
Cheers
Not that its going to matter as you can't see them with the fairing on but I know its done
- Has liked: 484 times
- Been liked: 81 times
Nice job looks professional!, my 2019 has the scab on the right TB , I was going to try and remove my centre stand for powder coating but I might spray it now.sakm wrote: ↑Sun Jan 08, 2023 5:58 pm While the bike was on the ramp I noticed that the left throttle body was pretty badly corroded in a couple of places
- Stu
Those springs look pretty tough to disengage… tempting to use brush hammerite
- Stu
Yes I agree! But at least they have something you can use the pull the springs
Others I have removed have just the spring
- Has liked: 81 times
- Been liked: 147 times
Put the bike on the centre stand and place washers between the gaps in the spring, push the bike off the stand and the spring stays extended and easier to remove. Repaint the stand then reverse the procedure.
- Stu
Its different on the RT There is actually something to use as leverage too
But that way looks a cracking idea
- Been liked: 327 times
Never had trouble removing a spring using one of these
Although I've never used the washers for spacers,that is 1 I shall remember and use in the future
- Stu
Thats what I was planning on usingburridge01 wrote: ↑Tue Jan 10, 2023 7:37 pm Never had trouble removing a spring using one of these
