Swingarm lower suspension protection
- Been liked: 327 times
Re: Swingarm lower suspension protection
I've got one of these on the way. Apparently it should fit and if it doesn't go far enough down I'll put some sort of extension on.
https://www.googleadservices.com/pagead ... EBA&adurl=
If it doesn't fit then at least I have a starting point for a proper rear hugger
- 7vwh
- Has liked: 16 times
- Been liked: 40 times
I tried something similar a few years ago but found the mounting bracket rubbed on the underside of the plastic ‘wheel arch’ when two up, so I sold it to a GS owner. Couldn’t remember how far down it reached in the area of the spring.
However, strangely, I’ve just bought another one from M&P to try again with some dremmel work
- 2D5266EC-863A-43F5-AC4F-1B6CF3F1B7C0.jpeg (739.67 KiB) Viewed 4493 times
Mine has just turned up
Reckon I'll spray the arm black before fitting.
Will be a while till I get in the garage so I'll see how you get on.Was your bike previously set up for 2 up full luggage?
- Steve398
- Has liked: 424 times
- Been liked: 348 times
I’ll be interested to hear the result…7vwh wrote: ↑Wed Jan 18, 2023 10:54 pm I tried something similar a few years ago but found the mounting bracket rubbed on the underside of the plastic ‘wheel arch’ when two up, so I sold it to a GS owner. Couldn’t remember how far down it reached in the area of the spring.
- Has liked: 1152 times
- Been liked: 306 times
Is there no way just to fix an old fashion mud flat to cover the gap? I did this to my Himalayan as every ride out the shock would get covered in mud.
Thanks to Excellent for the pic's
- 04C3C577-1169-4DC6-BE79-5B29631CB95B.jpeg (435.68 KiB) Viewed 4441 times
- Steve398
Just had a crawl through Aliexpress and found this for a GS. A good bit cheaper than Davids find and maybe worth playing with?Doctor T wrote: ↑Wed Jan 18, 2023 2:09 pm
Found this on Ali Express and wonder if this may fit. It states it for FOR BMW R1200R R1200RS LC R1250R R1250RS 2015-2016-2017-2018-2019-2020-2021
Wunderlich copy again. £4285 with £5.38 postage.
With a bit of bending and cutting you can make anything fit. There may be a splash guard listed on Ali but haven't found it yet.
https://www.aliexpress.com/item/1005001 ... 5xAPW2yKrH
https://m.aliexpress.com/item/100500433 ... fb3c32b6cb
- Steve398
Irrespective of the manufacturer this would (I hope) prevent the damage we all suffer to the stand.
From OEM parts it would appear that the GS/RT stands share the same part number.
It also occurred to me that some sort of lip on it may possibly also prevent the under sump spray onto the rear shock mount?
K'in ell Steve,stop posting this stuff up.Me bike won't move with all the gear I keep adding.Will take me a week to put it all on
P.S,,,,,,,,,got a link for the cheap 1
- Rossyuk39
- Bike Model and Year: RT 2015
- Has liked: 8 times
- Been liked: 5 times
- Contact:
Who pressed the "purchase" icon, damn Steve !!! You will have to buy me a Costa now !! Ali Express has some more £ out of me
Anyway, shocks upgraded & after seeing the state of both GS & RT rear shock units, including those which had seized at the bottom bushes & subsequently sheared, I made a rubber shield which protects the bottom bush from getting crud on it ....
This 2.5mm thick conveyor belt rubber, as you can see, wraps around the bottom of the swinging arm, no mud has so far found its way onto the bush.
Keep on the grey bits .....Rossy
- Bike Model and Year: R1250RT 2021
- Has liked: 25 times
- Been liked: 30 times
Thanks to Steve398 for the pic of the centre stand hack! I've got the perfect material for that - let the farkling re-commence. YESSSSS!!
- Steve398
I visited Bahnstormers the other day and tried the BMW GSA centre stand protector in an RT. Not an immediate fit but it may be possible to ‘make’ it fit somehow.
I may try a DIY effort with the conveyor belt material to see how that works instead.
Yes when I had a look last night - it'll need a bit of jiggling but it could be helpful.
