I found rear organic EBC pads but cant seem to find organics for the front. I see that the go to is the sintered pads, but I prefer the organics, can anyone link me to a part#??? Does EBC even offer an organic pad for the front discs?
**Edit** N'mind, after reading more comments I caved and ordered the HH. Thanks anyways....
TIA -Doug
Looking for Organic EBC front brake pads
- Bike Model and Year: 2009 BMW R1200RT-P
- Been liked: 13 times
Re: Looking for Organic EBC front brake pads
Quick follow up, while looking at the owners manual, I saw the rear pads spec'd organic and just assumed front and back were the same and that is not accurate. The manual stipulates sintered on the front discs.... so in spite of myself I actually managed to get it right.... : )
- Has liked: 1075 times
- Been liked: 281 times
The manual does say organic pads at the rear as you said. I had organic pads fitted to another bike. Found the feedback was terrible at the lever and my braking distance was longer. The only good thing about organic pads was the disc lasted longer. On my RT i fitted EBC HH front and back.
Here are the take offs from the rear caliper..... Not sure you can wear them any lower, the inside pad was almost to the bone....
- 20230214_164416.jpg (808.94 KiB) Viewed 3105 times
- 20230214_164322.jpg (1.02 MiB) Viewed 3105 times
- 20230214_164131.jpg (616.19 KiB) Viewed 3105 times
- Been liked: 379 times
From new, the BMW OEM inner pad is thinner than the outside. The hole is the wear limit, where the disc can be seen when looking through the wheel.
- Has liked: 11 times
- Been liked: 55 times
I don't think they do - at least I could not find those listed.
1983 GS1000G | 1984 GSX1100EF | 1997 FLHR | 1998 FLSTS | 1999 R1100RT | Triumph Tiger Explorer 1200 XRT
@David figured it was a wear indicator an you can def see through it..... : )
@Ed Harley Yep, I looked, none found, and as mentioned, I overlooked sintered front pads, I only NEEDED rears, so was a little focused on that job, but decided to swap the fronts out as well and just carried the "organic" portion of the show into the front brakes for a minute or three. After I couldn't locate any, and reading several posts about the EBC HH, I just "correctly" ticked that in the order column in spite of myself.....
