Flapper Valve.
DaveB28
Bike Model and Year: R1250 RT 2019
Has liked: 16 times
Flapper Valve.
Post by DaveB28 »
My exhaust flapper valve seized and a warning light has appeared on my dash. Headers were replaced under warranty last time it happened, but now its out of warranty BMW dont want to know unless I have £1600 to give them. Had a problem getting some of the screws out due to the restricted space and found this on Amazon
for £17. Money well spent and flapper valve now working, until the next time. Anyone have any idea if the flapper can be removed? How easy is it to do? And will it effect any future MOT due to its emmissions? Many thanks
Bike Model and Year: NUFFINK
Been liked: 327 times
Re: Flapper Valve.
Not sure about removing it but it won't affect the mot.When mine went I replaced the whole system with Arrow headers and exhaust.All for a grand and never have to mess with it again :thumb:
That's a tidy little set for the money,got a link :cheers:
Elkinell
Has liked: 104 times
Been liked: 57 times
Re: Flapper Valve.
Post by Elkinell »
Can't remember where I read it but the valve is more to do with getting around noise limits than emissions. There is a plug in bit of electrickery that goes under the seat that fools the canbus into not lighting up the fault if you disconnect the servo.
Re: Flapper Valve.
Disconnect the flap leaving it in the fully open position, remove the cables and actuator then fit a servo buddy to prevent the warning light on the dash coming on.
DaveB28
Has liked: 16 times
Re: Flapper Valve.
Post by DaveB28 »
Thanks for the advice folks really appriciate it. Here's the link for the mini wrench set
https://amzn.eu/d/99czprS
Re: Flapper Valve.
Cheers DaveB28 :thumb:
Has liked: 559 times
Been liked: 519 times
Re: Flapper Valve.
Servo eliminator as David says
https://www.healtech-electronics.com/products/ese/
remove the cables and motor and leave the flap wide open :thumb:
Elkinell
Re: Flapper Valve.
Post by Elkinell »
David. wrote: Wed Feb 15, 2023 6:50 pm Disconnect the flap leaving it in the fully open position, remove the cables and actuator then fit a servo buddy to prevent the warning light on the dash coming on.
THAT'S the fecker! :cheers:
Has liked: 53 times
Been liked: 46 times
Re: Flapper Valve.
DaveB28 wrote: Wed Feb 15, 2023 4:26 pm My exhaust flapper valve seized and a warning light has appeared on my dash. Headers were replaced under warranty last time it happened, but now its out of warranty BMW dont want to know unless I have £1600 to give them. Had a problem getting some of the screws out due to the restricted space and found this on Amazon20230213_102751.jpg20230213_102807.jpg20230213_102758.jpg for £17. Money well spent and flapper valve now working, until the next time. Anyone have any idea if the flapper can be removed? How easy is it to do? And will it effect any future MOT due to its emmissions? Many thanks
I removed my entire flapper butterfly last year. The pivot still moves in place, but there is just no butterfly to restrict exhaust flow. It had no negative effect on performance. What did happen was that I got some minor popping sounds from time to time when shifting gears.
DaveB28
Has liked: 16 times
Re: Flapper Valve.
Post by DaveB28 »
That sounds a good idea, as it did seem to be the flapper itself rather than the cables sticking. How did to get the flapper out?
Has liked: 53 times
Re: Flapper Valve.
I removed the muffler and used an electric die grinder. I was able to get the burr right along the pivot axel. Took about an hour to get it all off. There are probably easier ways. ;)
DaveB28
Has liked: 16 times
Re: Flapper Valve.
Post by DaveB28 »
Thanks for that, think I'll go with the healtec ese, a bit easier for a ludite like me.
Elkinell
Re: Flapper Valve.
Post by Elkinell »
DaveB28 wrote: Wed Feb 15, 2023 7:18 pm Thanks for the advice folks really appriciate it. Here's the link for the mini wrench set
Seemed too good to miss, It should be here on Sunday. The thing I bought to make the order up so I got free postage is supposed to arrive today. If it does I'll put a picture up ;)
Has liked: 484 times
Been liked: 81 times
Re: Flapper Valve.
I noticed these recently, they look fairly well made for the money.
https://www.blackwidowexhausts.co.uk/r- ... 8275-p.asp
Re: Flapper Valve.
Panman40 wrote: Mon Feb 20, 2023 8:07 am I noticed these recently, they look fairly well made for the money.
I have a set and they are well worth the money :thumb:
