Power ports and grip heaters ?
Has liked: 484 times
Been liked: 81 times
I’m finding various comments on the web regarding the max power draw for the power ports on the RT (2019 1250).
My initial plan was to try and add some paint protection to the rear grab rails as my wife does scuff them with her boots getting on. She also suffers cold hands so I thought I’d fit those wrap around Oxford heated grips but I’m not sure on the power needed to run them ?.
Also reviews say the Oxford are rubbish being either cold of burning your hands !.
Does anyone know for sure the max you can draw from the rear power port and if there’s a better alternative to the Oxford wrap arounds ?.
My wife doesn’t want heated gloves… I guess that would mean being attached to the bike with a cable ?, and she has tiny hands :lol:
smileymiley
Has liked: 6 times
Been liked: 11 times
Re: Power ports and grip heaters ?
Post by smileymiley »
I believe it's 10 amps overall over the 2 sockets.
Has liked: 1152 times
Been liked: 306 times
5 for the front/5 for the rear. You could always wire directly to the battery. I have a friend that bought a pair of cheap wrap around heated grips.
To use them on the grab handles he suggested that to first wrap the handles with tin foil. To stop the heat from dissipating into the plastic. After fitting the heated element he covered them in tennis bat tape.
Thanks!, something to think about. I’ll have a look and see if there’s another option than the oxfords.
Has liked: 133 times
Been liked: 69 times
As above 10amp between both sockets or 10amps for one socket.my gerbing draws 6.5 and ran fine from one socket.
Panman40 wrote: Tue Feb 21, 2023 7:32 amI’d fit those wrap around Oxford heated grips but I’m not sure on the power needed to run them.
"Draws under 3 Amps" https://www.oxfordproducts.com/motorcyc ... overgrips/
Panman40 wrote: Tue Feb 21, 2023 7:32 amMy wife doesn’t want heated gloves. I guess that would mean being attached to the bike with a cable.
Would battery powered heated gloves be an option.
Panman40 wrote: Tue Feb 21, 2023 7:32 amShe has tiny hands.
These 3-Finger gloves will probably be the warmest, sizes go down to glove size 5 - 3XS.
https://keisapparel.com/products/heated ... 1-3-finger
Thanks for the links, she really doesn’t like the idea of heated gloves :shock: , my life will be easier if I find another way :lol: .
Kim_Y
Been liked: 7 times
Post by Kim_Y »
Would it be easier to get a new wife?? 8-)
-Kim Y.
