Clutch bleed
pencile
Clutch bleed
Post by pencile »
I have a 2016 R1200RT that I need bleed the clutch fluid on. I can't find any good sources on just how to get to the bleeder valve. Its behind the starter as it looks. Does the starter need to come out (if that's even possible) ? does anyone have any information/instruction ? service manuals seem pretty vague on this subject.
Thanks good people!!
Has liked: 559 times
Been liked: 519 times
Re: Clutch bleed
Yes the starter hast to come out and apparently as does the slave cylinder
I think there is a frame rail in the way that stops you bleeding it in its position
Re: Clutch bleed
Found this for an R1200R, https://www.r1200rforum.com/threads/201 ... eed.52025/ may be similar to an RT.
Re: Clutch bleed
clucth bleeding.pdf
(908.24 KiB) Downloaded 234 times
pencile
Re: Clutch bleed
Post by pencile »
Thanks guys, I'll give it a hail Hail marry for the one David posted.. Can't believe they made this so epic!! LOL
Re: Clutch bleed
pencile wrote: Fri Mar 10, 2023 6:09 pm Thanks guys, I'll give it a hail Hail marry for the one David posted.. Can't believe they made this so epic!! LOL
Yes tell me about it! I was looking to change the clutch fluid on mine!
I might give the one David posted a go too. Although I suspect I can get in there with a tube and draw the fluid through with my vacuum pump
