centre stand painting
- Been liked: 20 times
Has anyone got some idea,s on how to keep the centre stand paintwork in good condition , sick of wire brushing and hammerite paint as it still gets covered in road crud and invariably ends up rusting , i was wondering if getting it stove enamelled would work ?
- Steve398
- Has liked: 387 times
- Been liked: 315 times
Re: centre stand painting
If you had a GS you could buy one of these from Wunderlich
- 5E387CC3-163D-43FE-8A25-FA4C8ED31E11.jpeg (194.53 KiB) Viewed 1847 times
- 65EA349A-D080-48B9-AB62-5BAA974C629D.jpeg (183.49 KiB) Viewed 1847 times
- Has liked: 1075 times
- Been liked: 281 times
Easy enough to make your own. I repainted my stand with Hammerite smooth
- Has liked: 13 times
- Been liked: 16 times
- Been liked: 379 times
- Stu
- Has liked: 540 times
- Been liked: 487 times
extremely easy with a home made tool
Those springs are bloody strong and I reckon I could have done it with a spring puller but I thought sod it I am making life easy
- Stu
Well I'm not trying now
I also didn't want to risk marking/chipping the nicely powder coated stand
- Has liked: 14 times
- Been liked: 79 times
I recall seeing a video a while back by a fella took off his stand, cleaned it, painted it, covered the cross section that's in the firing line with waterproof grease, then covered that with a short length of black PVC (plumbing type) tubing. It all sounded a bit OTT to me, but he was happy with the end result.
Centre stands do get hammered with gravel rash, (particularly the crossbar between the two vertical legs), resulting in corrosion. Not wishing to remove the stand, I rubbed down the horizontal tube, brush painted with Hammerite Smooth then fitted a length of plastic tubing for future protection.
- Has liked: 422 times
- Been liked: 56 times
