Auxiliary light brackets
- Stu
- Has liked: 559 times
- Been liked: 519 times
I have ordered some heed engine bars and I need to remove the auxiliary light brackets and replace them with something else
Anyone got any recommendations? particularly ones that will fit the BMW lights on
I have seen some lights mounted between the fairing under the front light which looked good but can't find any brackets for them
- Stu
Re: Auxiliary light brackets
Thanks but mine is a 2016 modelGlacial wrote: ↑Tue Apr 25, 2023 10:25 pm Try this?
https://www.ebay.co.uk/itm/185301338240 ... media=COPY
- Has liked: 1152 times
- Been liked: 306 times
Denali does mounts that fit just below the mirrors but a bit expensive at £116. Also there is Heed and Givi. I think Wunderlich do some
- Steve398
- Has liked: 424 times
- Been liked: 348 times
Dependant on the fixing, are either of these suitsble?
https://m.aliexpress.com/item/100500450 ... 4itemAdapt
https://www.ebay.co.uk/itm/115608053477 ... media=COPY
- Stu
Yeah the denali ones are a bit on the steep side!
By the looks of it I will be fitting them to the engine bars using something like what Steve linked to
I have Illium brackets. But again not a cheap option. Sportouring are a uk supplier
- Stu
Found some but not sure if I like the position they are in!
I wanted them higher or in a similar position to the standard ones but the brackets and bar combination just won't allow that position!
Am I being too picky?
If they stay there I will need to extend the wiring
- 343554157_190143163450067_201830630729137158_n.jpg (242.78 KiB) Viewed 1927 times
- Has liked: 484 times
- Been liked: 81 times
Will they not fit on the top part of the bar ? .sakm wrote: ↑Tue May 02, 2023 8:47 pm Found some but not sure if I like the position they are in!
- Stu
Not really!
The brackets are pretty big and can't get the correct angles due to fouling with the engine
Plus the rear of the lights touch the engine too
Here are mine on the Illium brackets, they are full adjustable on all planes.
- Stu
What about these?eBay item number:185802988180
eBay item number:404239281635
https://www.aliexpress.com/item/1005003 ... lgo_exp_id
https://www.aliexpress.com/item/1005003 ... e0ALC6e3BD
https://www.aliexpress.com/item/1005001 ... o_exp_id=c
- Stu
These are the ones I bought already
They fit and work I'm just not sure if I am happy with the position
Ps the links didn’t work so I just used the item number
- Stu
Extended the wiring for the lights the other night!
I went the whole hog and removed the loom for the lights and extended them at the top end where it is all hidden and taped it all back up and it looks stock! well what you can see of it anyway
Lights look OK where they are now they work
