Auxiliary light brackets
Has liked: 559 times
Been liked: 519 times
Re: Auxiliary light brackets
Discovered tonight that the lights are too close to the floor when going round corners!
Back to the drawing board before I scrape one on the deck
Has liked: 484 times
Been liked: 81 times
sakm wrote: Thu May 11, 2023 9:06 pm Discovered tonight that the lights are too close to the floor when going round corners!
That’s annoying!, I can’t remember the last time I rode in the dark…🤔🤣
Panman40 wrote: Thu May 11, 2023 9:46 pm That’s annoying!, I can’t remember the last time I rode in the dark…🤔🤣
They don't get lower when I turn them on 😂
A mate was following me and said they was about an inch off the floor and we was only going steady 😳
Has liked: 1152 times
Been liked: 306 times
Have you any pictures Stu
Doctor T wrote: Fri May 12, 2023 3:44 pm Have you any pictures Stu
There's some on page 1
None of them almost on the floor though 😂
I know it may weaken the bars but cant you drill a hole in the top section to receive a small sleeve and drop the spot lamp bolt through it? You could weld the sleeve in the hole for added strength.
If this doesn't work How about welding a steel bar to the top section for a spot mount? Sprayed with satin matt paint to cover the welds.
Doctor T wrote: Fri May 12, 2023 4:18 pm I know it may weaken the bars but cant you drill a hole in the top section to receive a small sleeve and drop the spot lamp bolt through it? You could weld the sleeve in the hole for added strength.
The bars are too close to the engine to allow the spots to sit there.
The mounts I have protrude forwards but it's still not enough!
I am going to have a look and see if I can tuck them in a bit more
can you take a sideways pic. So i can see if i can make or come up with a solution for you
Bike Model and Year: NUFFINK
Been liked: 327 times
sakm wrote: Fri May 12, 2023 4:23 pm The bars are too close to the engine to allow the spots to sit there.
You will eventually succumb to Denali :thumb:
Doctor T wrote: Fri May 12, 2023 4:34 pm can you take a sideways pic. So i can see if i can make or come up with a solution for you
Thanks for the offer but I'm not adverse to a bit of fabrication if needed but I don't want to start welding stuff on to new bars and then having to get them powder coated again!
I have the perfect solution sat on the bench in the shape of the stock light mounts but as I say I don't want to weld them on
burridge01 wrote: Fri May 12, 2023 6:13 pm You will eventually succumb to Denali :thumb:
Never 😂
Although I might order the mounts take some measurements and send em back 😂
sakm wrote: Fri May 12, 2023 6:41 pm Thanks for the offer but I'm not adverse to a bit of fabrication if needed but I don't want to start welding stuff on to new bars and then having to get them powder coated again!
No probs. Please still do a sideways pic as i may be able to extend your mounts without having to weld. I have so many bits and pieces that i may have a piece that would just slide in between the mount and light bracket.
I will do when I get 5 mins :thumb:
@Doctor T
As requested
Needs a bloody wash :lol:
I see now. There's not much movement or anywhere else to mount them. I will say my highway pegs are fitted lower and ive never got anywhere hitting the going around corners. Personally, i would move the spot mounts lower down near the downpipes and then they would be tucked in more and out of the way
