Auxiliary light brackets
- Stu
- Has liked: 559 times
- Been liked: 519 times
Re: Auxiliary light brackets
Discovered tonight that the lights are too close to the floor when going round corners!
Back to the drawing board before I scrape one on the deck
- Has liked: 484 times
- Been liked: 81 times
- Stu
They don't get lower when I turn them on
A mate was following me and said they was about an inch off the floor and we was only going steady
- Has liked: 1152 times
- Been liked: 306 times
Have you any pictures Stu
- Stu
I know it may weaken the bars but cant you drill a hole in the top section to receive a small sleeve and drop the spot lamp bolt through it? You could weld the sleeve in the hole for added strength.
If this doesn't work How about welding a steel bar to the top section for a spot mount? Sprayed with satin matt paint to cover the welds.
- Stu
The bars are too close to the engine to allow the spots to sit there.Doctor T wrote: ↑Fri May 12, 2023 4:18 pm I know it may weaken the bars but cant you drill a hole in the top section to receive a small sleeve and drop the spot lamp bolt through it? You could weld the sleeve in the hole for added strength.
The mounts I have protrude forwards but it's still not enough!
I am going to have a look and see if I can tuck them in a bit more
can you take a sideways pic. So i can see if i can make or come up with a solution for you
- Been liked: 327 times
- Stu
Thanks for the offer but I'm not adverse to a bit of fabrication if needed but I don't want to start welding stuff on to new bars and then having to get them powder coated again!
I have the perfect solution sat on the bench in the shape of the stock light mounts but as I say I don't want to weld them on
- Stu
Never
Although I might order the mounts take some measurements and send em back
No probs. Please still do a sideways pic as i may be able to extend your mounts without having to weld. I have so many bits and pieces that i may have a piece that would just slide in between the mount and light bracket.sakm wrote: ↑Fri May 12, 2023 6:41 pm Thanks for the offer but I'm not adverse to a bit of fabrication if needed but I don't want to start welding stuff on to new bars and then having to get them powder coated again!
- Stu
@Doctor T
As requested
Needs a bloody wash
As requested
Needs a bloody wash
- PXL_20230512_210132328.jpg (276.73 KiB) Viewed 1243 times
- PXL_20230512_210044063.jpg (262.27 KiB) Viewed 1243 times
- PXL_20230512_210035984.jpg (285.09 KiB) Viewed 1243 times
- PXL_20230512_210030419.jpg (275.72 KiB) Viewed 1243 times
- PXL_20230512_210025726.jpg (262.21 KiB) Viewed 1243 times
- PXL_20230512_210123400.jpg (328.7 KiB) Viewed 1243 times
I see now. There's not much movement or anywhere else to mount them. I will say my highway pegs are fitted lower and ive never got anywhere hitting the going around corners. Personally, i would move the spot mounts lower down near the downpipes and then they would be tucked in more and out of the way
