2007 R1200RT
I have a "DWA" warning on the dash. This means the alarm backup batteries need replacing
They are in a little black box, underneath the rear rack
Can someone tell me how to access this so I can unscrew the screws on the box? It looks like the rear rack has to come off, but I can't get the bolts on the rack undone, they just keep turning, but not loosening. The nuts are not accessible, as they are inside the plastic of the rack
I've seen this
https://touron2wheels.wordpress.com/201 ... ion-alarm/
But these two bolts, shown in this photo, will not undo
Can anyone help???
DWA warning - help needed
- Been liked: 327 times
Re: DWA warning - help needed
I was thinking that,it looks like it parts just above said bolts and then just maybe you tension the part while undoing it,if that makes sense.Possibly pulling the part away as you undo the bolts.
- Has liked: 1 time
- Been liked: 6 times
I have come across this. Once the inserts in the plastic start to spin you are very unlikely to get the bolts out. They will have corroded (dissimilar metals I think).
You can try applying some penetrating oil to it, but you dont want any to get to teh outside of the insert. Once the oil has soaked in you can try applying pressure by wedging a screwdriver in the gap between the rack and the biketo try and get the inserts to bite, but I would not hold out too much hope.
hi, yes, looking at the comments on that webpage it looks like i am not aline and the bolts will not undo as the nuts are spinning, and they cannot be accessed at all
i will just leave it, i don't use the alarm anyway, but it seems like a pretty crap way to design it...
- Has liked: 81 times
- Been liked: 147 times
Would a Jubilee clip tightened up around the plastic help to get more purchase to stop the nut spinning?
possibly. i'm fed up with it now, so i am just going to leave it. it will get added to all the other faults the bike has! (abs gone, fuel strip gone)
