Riding down the road, minding my own business, and the windshield tipped back. Only 1/2 mile from home, so I finished my trek.
Get in the garage to find the two pins or bolts that hold the bottom of the windshield to the up/down frame are gone!
Now, I am on a mission to replace them. Local shop’s closed today. I found an on line microfiche, but the parts are not listed. Anyone help me?
Anyone else?
- Bike Model and Year: R1250 RT LE 2019
- Has liked: 15 times
- Been liked: 14 times
Re: Anyone else?
BMW do sell them individually, mine are inbound as I found one missing last week. Ordered a couple and the clips for around £30 delivered. I couldn’t find anything online that matched. Sorry I don’t know the part numbers yet. The other one was missing its clip and was just about to disappear. I managed to make a temporary repair by cutting down a footrest pin that was close to the same diameter. As far as I can tell they start to bind up then work out as they twist each time you raise the screen. I have greased them and over the weekend the screen was nice and solid.
- 60Aviator
- Has liked: 8 times
Re: Anyone else?
This is what works on my 21 RT. I can't remember where I got them, Amazon, Grainger, McMaster Carr, Fasenal, Lowes, etc..
- 20230530_060322.jpg (211.89 KiB) Viewed 1963 times
- 20230530_060311.jpg (148.43 KiB) Viewed 1963 times
- 60Aviator
Re: Anyone else?
This is where I heardf about these:
https://www.bmwlt.com/threads/k1200lt-w ... st-1980814
- Stu
- Has liked: 540 times
- Been liked: 487 times
Re: Anyone else?
I have just ordered some pins in two different sizes with split pins instead of clips
I will let you know of my findings before I post any links
Re: Anyone else?
on my 2007 RT i had all four screen "arms" break and the screen almost came off when i was riding. i replaced them with steel ones as the original ones go brittle over time and break
another BMW design fail....
- Bike Model and Year: 2020/RT
- Has liked: 3 times
- Been liked: 2 times
Re: Anyone else?
I found bmw parts. Typically priced bmw parts!
Bobs bmw in Maryland.
Talked to one of the parts guys (drew, I think). The shipping price automatically set on the website was crazy. He made it right.
Ain’t no right way to do the wrong thing.
- Has liked: 6 times
Re: Anyone else?
I've just had the same on my 2020 R1250RT.
I was washing the bike and lifted the screen to the highest position to clean the underside. Noticed that the lower left pivot pin was missing completely. The e-clip was missing from the lower right side pin, but the pin was still in position.
I can only assume that the e-clip has dropped off the left pin and allowed the pin to vibrate loose. Presumably, the right side pin would have followed if I hadn't spotted it and fitted a new e-clip.
Interestingly, both upper pins were still in position and both e-clips were present.
Replacement lower pin is on order, expected next week. I'll remove all 4 pins and clean/lubricate them on reassembly. According to the parts microfiche, the upper and lower pins are slightly different sizes. That's not a sensible engineering approach.
- Bike Model and Year: 2019 BMW R1250RT
- Has liked: 1 time
Re: Anyone else?
Just checked my motorcycle today, all pins are there, but one circlip missing and the pin was moving out.
Thanks for sharing this info.
Cheers
David
Cheers
David
