New 1250 RT LE
Lordwanswell
Bike Model and Year: BMW K1300GT
New 1250 RT LE
Post by Lordwanswell »
Am now the proud owner of a brand new machine, first time I have a brand new bike for 50 years. Any running in tips?
Elkinell
Has liked: 104 times
Been liked: 57 times
Re: New 1250 RT LE
Post by Elkinell »
Congratulations on your new bike! I have no tips other than what your manual will tell you. I have only had two brand new bikes and there were in the early 80's, strangely enough I found the rusted, dented tank from one of them in my dads shed a couple of weeks ago.
jesim1
Has liked: 120 times
Been liked: 74 times
Re: New 1250 RT LE
Post by jesim1 »
I've just run mine in.
They are pretty quick bikes, so I found I had to use lower gears progressively to achieve higher revs to get it run in properly by around 600 miles when it went for it's first service.
For example (and the figures will not be exact, they are just examples)
I would be on the motorway and be using 3/4/5/6 gears while still doing 70/80mph so I could get it doing 5/6/7000 revs etc....... I slowly worked up to getting it red lining in the lower gears as the miles passed and I worked up to them doing this over several hundred miles on various roads. It's not great for it to do steady speeds while running in, so use the gears to vary it if you have to be on a motorway for example.
I think the first hundred miles I only went to about 3/4k revs, and then about another thousand on top of that ever 100 miles or so.
The whole point of running it in is to slowly get the engine running faster to wear off any crap still on the new components, and then do the first service to get rid of any of the crap which will now be in the oil/filter as well as check over things have not gotten loose etc.
This is what I do anyway, and it's never caused me an issue, with all my bikes never developing any kind of engine issues.
I'm sure there is more than one way to skin a cat :thumb:
exportman
Has liked: 9 times
Re: New 1250 RT LE
Post by exportman »
Don't leave it to chug along at low revs, its not a diesel vehicle. Vary the speed /revs acceleration and deceleration using the throttle control.
Enjoy the bike, they are much more fun over about 4000 rpm
Has liked: 1152 times
Been liked: 306 times
Re: New 1250 RT LE
A warm welcome to our site and congratulations on your new arrival. :-D
